I'd like to go lower...
  • M3Philipp
    • Jul 2011
    • 278
    I own an 1990 318is.
    Right now I'am using Eibach springs and dampers, that lower the car around 40/30.
    Now I would like to go abit lower, without buying new springs and dampers again.:down:
    Is there anything I can do about it, or is the only way by using different springs.
    I would be happy if the car drops atleast alittle more.;)
    Thanks in advance...
  • Holland
    • Nov 2008
    • 7212
    You could play with spring pads or drop hats. Could always do a little snip snip on the springs too, although I wouldn't advise it on the rears.
    Originally posted by DEV0 E30
    • FunfGan
      • Jan 2011
      • 4958
      Take the pads out and chop the fronts. I really would NOT advise the rears anyway hahah.
      Go here be happy!
      Ratchet Garage e30 V8 build.
      • Holland
        • Nov 2008
        • 7212
        Could always try and shrink them like a lowrider, but who knows how they would perform.
        • bmwguy325is
          • May 2011
          • 1263
          Ya just ditch springs all together. Just ride on the bump stops. Thats the best free mod eva. I however, wouldnt listen to me my car is not low enough by forum standards.
          sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
          The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
          • FunfGan
            • Jan 2011
            • 4958
            Bumpstops are made rubber for a reason, they're still bouncy with no springs
            Go here be happy!
            • einstein57
              • Jun 2007
              • 10780
              Originally posted by FunfGan
              Bumpstops are made foam for a reason, they're still bouncy with no springs
              fixed
              www.gecoils.com
              • E30_fiend
                • Apr 2006
                • 7348
                Im with this guy ^^^^^
                There really isn't much you can do in the rear with the exception of pulling out the rear pads. At the MOST, it will lower the rear about 1/4". The spring pads are pretty thick but they ARE rubber so they compress quite a bit.
                Taylor
                • FunfGan
                  • Jan 2011
                  • 4958
                  If the Eibachs are similar to the H&R sports(am I wrong?), you could get a pretty nice drop out of just doing all that. As E30_Fiend said, back won't go much lower, but it will still fix that reverse rake get you lower in the front!
                  Go here be happy!
                  • E30_fiend
                    • Apr 2006
                    • 7348
                    Naw man, the EIbachs fuggin DUMP the car. That was my first setup. H&Rs are a mild drop. Not only are they way low, they are crazy soft.
                    Taylor
                    • FunfGan
                      • Jan 2011
                      • 4958
                      Oh damn, well forget that then. You'll get low.
                      Go here be happy!
                      • E30_fiend
                        • Apr 2006
                        • 7348
                        OP, I suggest cutting your bumpstops so you dont blow your shocks. The eibach kit sits way too low to be that soft. Its asking for problems IMO
                        Taylor
                        • M3Philipp
                          • Jul 2011
                          • 278
                          Has nothing to do with what I'm reading here by others.
                          But I've seen some very cool and low e30's here, and I really love that look.
                          Not talking about insane low, but lower.
                          Thanks for all the tips so far guys.
                          • Ant_e30
                            • 292
                            Get coilovers. You're in germany so look at KW V1s or V2s if you want damper adjustment
