SRS Airbag Indicator Flashing after installing shocks/spring
  • Jon '92 325ic
    • 172
    Hey,
    Sorry if this is a lame question. I did a search and didn't find the answer so here goes:
    I took my '92 325ic to have Bav Auto Springs and OEM Boges installed. The shop installed ok, but the SRS Airbag was flashing (and still is).
    Is this a common occurrence when installing a new suspension?
    Is this a quick fix?
    I took the car back and the head mechanic said the SRS has nothing to do with the suspension. I'm guessing there's a sensor for the airbag near the front suspension that they messed with.
    Thanks,
    Jon
  • Jordan
    • 12916
    Re: SRS Airbag Indicator Flashing after installing shocks/sp
    The connector for the SRS sensor on the front fender well is very similar to the ABS connector. $5 says one of them got disconnected on accident.
    It is now their responsibility to reset the light.
    https://mtechniqueabs.com/
    • Jon '92 325ic
      • 172
      Thank you
