Any benefit to m3 offset CA bushings on stock suspension?
  • Stanley Rockafella
    • Aug 2011
    • 4062
    My one bushing is bad, so I figure I may as well replace everything while I'm in there. is there any benefit to upgrading to m3 offset bushings considering the rest of the suspension is all stock?
    thanks in advance!
  • browntown
    • Jun 2004
    • 3524
    I *think* it will offer better geometry on a lowered car. I just went to treehouse eyeball arms and never looked back. I believe they have the same geometry as the m3 cab's.
    • reelizmpro
      • 9559
      They'll give you more caster for high speed stability. They are also solid so they should last a lot longer (life of the car?) than the stock bushings. It's a worthy upgrade in my opinion and they aren't expensive.
      88 M3 - LACHSSILBER
      89 M3 - ALPINEWEISS II
      • george graves
        • 20003
        Don't do it on a stock set up. I ran them on mine for a few years and it tends to eat up tires in a hurry.
          • Aug 2011
          • 4062
          by "more" caster, do you mean more Negative, or more positive?
          • chadthestampede
            • Jul 2008
            • 3601
            http://en.wikipedia.org/wiki/Camber_angle
            Caster, not camber.
            Originally posted by LJ851
            Feedback
              • Aug 2011
              • 4062
              awe, my bad
                • Aug 2011
                • 4062
                woudl these be a suitable upgrade given the additional rubber to make it more solid over stock?
                31 12 9 069 035
                thanks
                • einstein57
                  • Jun 2007
                  • 10780
                  You can also get the e36 m3 control arm bushings. They are solid but not offset.
                  www.gecoils.com
                  • Leo_328i
                    • 226
                    I'm running this on my 318iS and it feels great.
                    I'll be upgrading to the offset bushings when I shove in the 24v motor because it pushes the front wheels forward a few mm which should help help the front end of the car feel less nose heavy (though only slightly)
                    Leo.
                    E30 318iS, E36 328i
                    • trackjunkie21
                      • Jan 2010
                      • 3962
                      You need to have the toe angles corrected, when the caster is increased, it increases the toe in angle, hence the tire wear.
                      Originally posted by Wh33lhop
                      VANOS: sometimes you just need to go full retard.
                      • lbreevesii
                        • Aug 2009
                        • 412
                        ^ this.
                        Better stability, won't wear out, cheap, win.
                        I don't always wreck cars, but when I do I wreck them into trees.
                        91' 318is S50 swap - The Black Widow
