H&R Race Springs + Lift Kit.
I've purchased several myself. The problem i've found is that each corner of a race car uses a different rate. You have to be patient to find two springs of the same rate. The other hard part is to find a spring that is short enough with low enough spring rates. I highly recommend welding on a perch 2" lower then the factory one in the front. This will allow you to use 7" and 8" springs which will vastly increase your usable selection. Although this will be dictated by your wheel backspacing.
I have some of these laying around. lol
http://www.ebay.com/itm/Mountain-Bik...b#ht_500wt_715Last edited by einstein57; 12-21-2011, 06:11 PM.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
How does one open up the bilsteins to do this?
I've been trying to find info on diy revalving but can't seem to. Some books suggest that bilsteins are some of the easiest struts to rebuild in your garage, but that was back in the day.Comment
