H&R Race Springs + Lift Kit.
  • LJ851
    • 7918
    So i just put H&R Sport Springs w/ KYB shocks on and while i loved the ride height, the ride was closer to stock than i wanted. I bought some used koni sports from a fellow r3vr and after thinking about it and looking at a lot of pics i ordered some H&R Race springs. My goal was to have about the same ride height as my Sports were giving me but a firmer ride.
    I decided to do the rear of the car first and was really bummed when i put the car on the ground cause it was a lot lower than before, like 1.25 inches lower.
    Being bummed i called it a night and decided to put the Sport springs back on. I contacted another r3v member who was looking for Races to see if i could sell mine to him but he had just bought some. Damn. After discussing my dilemma i decided to go ahead and try the front races as i found out they tended to lower the back more than front. (Thanks, P!)
    The front Races only lowered the front .25 inches compared to Sports. This i could live with. (My E30 is my sensible car)
    So in a move that goes against the very core of r3v i decided to raise the back of the car to match the front.
    I found some tough as shit plastic in my stash that was .20 inches thick and did this:
    I made 8 spacers but only ended up using 6 (3 on each side) There is one above the upper spring pad and two below the lower spring pad. It was exactly what i wanted .25 inch drop all around and i really like the taut ride of this setup.
    Lorin
    The M30 is God's engine.
  • reelizmpro
    • 9469
    I did the same thing on my vert except with extra spring pads I had.
    88 M3 - LACHSSILBER/SCHWARZE
    • ill4noreason
      • 2710
      Pic of ride height?
      My Multi car part out. Need a part? Pm me...
      http://www.r3vlimited.com/board/showthread.php?t=193051
      Need 24v swap parts? How about a LSD? Plastic Bumpers? Or anything else click here...
      http://www.r3vlimited.com/board/showthread.php?t=215044
      Have you done business with me? If so leave me feedback here...
      http://www.r3vlimited.com/board/showthread.php?t=188307
      • reelizmpro
        • 9469
        Extra pads in the back, none up front.
        • LJ851
          • 7918
          It's dark and raining in Atlanta right now, I will take some pics tomorrow and post up.
          Lorin
          • blefevre
            • Dec 2008
            • 4287
            Can you just stack the stock rear ones together or did you cut them up? How many pads did you use?
            - E30, DSM, Golf R, Mazda 3 Skyactiv
            • reelizmpro
              • 9469
              You can either run extra bottom pads or cut the big nipple off the top ones and use those.
              • LJ851
                • 7918
                I have all the spring pads on plus the .60 inch spacers in the rear. The trunk tar has been removed.
                Pic:
                Lorin
                • 110stx
                  • Sep 2011
                  • 253
                  Pardon the threadjack, but your car ^^^ is gorgeous.
                  STX e30
                  No. 10/110 STX: 1989 325i
                  DD: 1991 318is slicktop
                  SHAZAM, GOMER, LOOK AHEAD.
                  • bastianshaw
                    • Jan 2007
                    • 2210
                    I had the same problem, used the same fix
                    before:
                    after:
                    doing this has the added benefit of reducing camber and making your rear a bit stiffer+increases oversteer. Highly reccomend
                    • LJ851
                      • 7918
                      Thanks, man!
                      Lorin
                      • taiden
                        • Oct 2009
                        • 178
                        Looks good LJ851. How much lower was it before?
                        I never liked the effects of lowering, but I've always loved the effects of high rate springs. Too bad no one combines the two. It's the main reason I'm trying to spec out my own springs.
                        • einstein57
                          • Jun 2007
                          • 10780
                          Coilovers?
                          www.gecoils.com
                          • taiden
                            • Oct 2009
                            • 178
                            Originally posted by einstein57
                            Coilovers?
                            Definitely an option, although I'd rather get them right the first time and use shims for counterbalancing. Call me oldschool
                            • Sagaris
                              • Sep 2009
                              • 2243
                              I just came from the How to Modify front JOM coilovers to go lower? thread. I feel much more comfortable in this thread. :D
                              I think rasing the car with h&r race springs is an excellent idea.
