Truth about Toe and Camber
  • aTron12
    • Nov 2009
    • 98
    I have read a bit through these forums recently about how TOE is a bigger cause for inner tire wear than camber. Is this really true? And if it is, then when I get my rear aligned next week (i have a toe/camber kit on the rear subframe) should I be asking for a little negative camber? ... Or do they both wear out your tires if out?
    PS. I'm running H&R sports and Bilsteins.
  • Holland
    • Nov 2008
    • 7212
    Negative camber will cause uneven wear. Toe accelerates wear.
    Originally posted by DEV0 E30
    • aTron12
      • Nov 2009
      • 98
      So then the smartest thing to do here is just get my tires back to 90ยบ and spec for toe and call it a day? I'm not tracking.
      • Vtec?lol
        • Dec 2009
        • 3278
        I wouldn't say 90, you will still want some negative camber dialed in for street use. Not so much in the rear.
        Rotating/camber-flipping your tires will drastically increase tire life but that doesn't mean wait till the inner tire is bald. Timing is key here
        • aTron12
          • Nov 2009
          • 98
          So then I'll ask for a slight negative camber in the front and spec for the toe in the front. I am assuming if the toe is perfect with slight front camber I shouldn't wear too bad on the front? Also the rear is okay at 90 degrees?
          Thanks
          • bmwguy325is
            • May 2011
            • 1263
            So have the shop put it close to the factory specs if you dont want a lot of wear.
            sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
            The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
            • LJ851
              • 7919
              This. Factory Specs.
              Lorin
              The M30 is God's engine.
              • aTron12
                • Nov 2009
                • 98
                Done.
                • Ant_e30
                  • 292
                  camber only seems to cause very accelerated wear when you get beyond -4 or so. up until then it just causes uneven wear rather than causing it per se
                  • DRTSRFR
                    • May 2008
                    • 1836
                    If the car is lowered, you won't be able to get factory camber.
                    That said, as mentioned above, toe will be the tire killer.
                    Suspension tips here...
                    http://www.r3vlimited.com/board/album.php?albumid=757
