Called up kyb, gr2's/excel g's are the softest, then gas a adjust, then agx.
Camaro Shocks
Thanks guys for this thread... It has been informative and very reassuring. I have long wanted to sort out the front shocks in my car since the euro s50 upgrade... Nothing did it good enough.
I have coil overs up front, 550lb springs and in the rear I'm running 650lb springs on perch with dihatshu rocky 4x4 bilsteins. I'll look into the kyb agx now and report back...
Cheers once again for some great researchSignature removed by R3V staff due to a violation of the forum rulesComment
i dont want to run super stiff shocks. i want a ride that is moderately stiff but not too stiff but not too sofft at the same time. I have 5" 450lb springs in the rear. would gr2s, gas a just, or agx on the lowest setting be good for what im looking for?Comment
Im running ST M3 Springs in my 325e, and am considering going the mr2 KYB AGX route for the front. I ordered the bearings already, and know I will have to run spacers since I don't plan to cut the strut tube.
I don't know what strut insert to run in the front. Will the rear mr2 shocks (even at the lowest setting) be too stiff a shock for the ST springs?
Would the front mr2 shocks be a better choice instead?
Am I better off just putting down the money for bilsteins and calling it a day?Comment
If you are planning to go with the MR2 struts in the front, I say just go with the camaros in the rear. I think they are stiff enough and will match. At the end of the day though, everything is subjective and I dont think I am even a good candidate to measure how "stiff" suspension is by just riding in the car. I either like the ride or I dont. I however would like to say that I like the Camaro rears - feels solid. And I have everything Poly in the back with no Sway. As far as the front, I will tell you what my revalved billies feel like once my oil pan is back in.Comment
I've been running AGX's (MR2 fronts / Camaro rears) for a while now, and have quite a few track days on them. I love the combo. I can dial it down for daily use, and really stiffen it up for track days. I am paired with H&R race springs, ST sways.
I'd really like to hear more feedback from other users and what combos you are running______________________________________
1984 LSB 318i - Sold
1986 325i - Motor Swapped Track Car Project
1995 318ti - Sold
1999 540iA - Daily DriverComment
well i just got my Camaro KYB excel-g rear shocks and pulled my current tokico blues off the rear of my 88 325.
side by side comparison shows the KYB's to be 1.5" shorter then the Tokico's. and pressing on the two of them to my surprise the tokico's are much stiffer then the new KYB's. this has me concerned because i was hoping to pick the back end of my car up a little bit with stiffer shocks. i guess i should have got kyb gas-a-just or agx's but i thought the increased rear weight of the 4th gen camaro would lend to a stiffer shock period. at this point im unsure if i will use these. im sure they would be a nice upgrade from some beat stock shocks, but the fact that they are much easier to compress than the well used tokico blues makes me think they may have been a waste for my car.
any thoughts?Shawn @ Bimmerbuddies
Bimmerbuddies LLC
717-388-1256
2971a Roundtop Rd, Middletown PA 17057
bimmerbuddiesllc@gmail.comComment
Shocks aren't designed to have effect on ride height, they are designed to control your springs. If you want to adjust your height, it's going to be in the spring, not the shock.sigpic
Instagram @rebellionforgeComment
i understand that is not their intended purpose but putting stiff new shocks in place of beat ones will raise the car up, thats why i no longer rub up front because i replaced cheap Stagg front shocks with new billy sports and it raised the front about an inch.
but with ride height aside these excel g's still are much easier to compress then my old tokico blue's so i dont see them helping me aside from the fact that they are shorter and thus wont let my suspension drop so much when it uncompressed.Shawn @ Bimmerbuddies
Bimmerbuddies LLC
717-388-1256
you are so wrong... spring height is the only thing that will change the level of the car. Shocks stop the movement of springs only.i understand that is not their intended purpose but putting stiff new shocks in place of beat ones will raise the car up, thats why i no longer rub up front because i replaced cheap Stagg front shocks with new billy sports and it raised the front about an inch.
but with ride height aside these excel g's still are much easier to compress then my old tokico blue's so i dont see them helping me aside from the fact that they are shorter and thus wont let my suspension drop so much when it uncompressed.2014 Alpine White 335i MSport
(Daily Driver)
Full Mperformance Aero
KW V2 Coilovers
VRSF Catless DownpipesComment
Just saying what happens on my car, stiff new shock make it ride at a higher height then blown out old shocks. If you find that impossible to believe the so be it but I don't rub any more so the diffrence is clear to meShawn @ Bimmerbuddies
Bimmerbuddies LLC
717-388-1256
