Camaro Shocks
  • IronFreak
    • Dec 2012
    • 3702
    #256
    Here ya go:
    http://www.kyb.com/technical/documen...onsSecured.pdf
    Go to page 15, 4th line item down. Part#743019 compressed length of 12.13".
    Instagram @rebellionforge
    • CubbyChowder
      • Mar 2012
      • 1487
      #257
      Originally posted by IronFreak
      Here ya go:
      Thank you!
      --Roundie Revival 2.0 - 1973 BMW 2002 Build Thread--
      --Golden Boy E30 Build Thread-- (sold)
      • Mr. Tasty
        • Jul 2011
        • 3421
        #258
        Originally posted by CubbyChowder
        Thank you!
        if 12 inches compressed isn't enough, just look for e1 top mount, and s1 bottom mount. Then look for a smaller compressed lenght.
        2014 Alpine White 335i MSport
        (Daily Driver)
        Full Mperformance Aero
        KW V2 Coilovers
        VRSF Catless Downpipes
        • Balleristic31
          • Aug 2009
          • 4198
          #259
          How are you guys pressing out your old strut bearings?
          -NICK
          • Mr. Tasty
            • Jul 2011
            • 3421
            #260
            just get the shock turned down by 1mm
            (Daily Driver)
            KW V2 Coilovers
            • Balleristic31
              • Aug 2009
              • 4198
              #261
              Yep decided to do this after a ton of hassle. Thanks
              -NICK
              • Andy.B
                • Sep 2011
                • 1650
                #262
                I accidentally ordered 3 instead of 2 kyb agx camaro rear shocks. I realized it the second my finger came up from the mouse button and saw that the total was higher than I expected. My stupidity can be someone elses gain though, as I will have 1 kyb agx Camaro rear shock for sale shortly.
                • Mr. Tasty
                  • Jul 2011
                  • 3421
                  #263
                  how much did this cost you btw?
                  (Daily Driver)
                  KW V2 Coilovers
                  • Andy.B
                    • Sep 2011
                    • 1650
                    #264
                    It cost me $30 cash and was done within 2 hours at a local machine shop.
                    • Balleristic31
                      • Aug 2009
                      • 4198
                      #265
                      I was quoted 75 at a local machine shop so I improvised. Impact gun with the nut on the end of the strut to spin the shaft and let the file do the work :) seems ghetto but worked absolutely perfectly. Car is now bolted up and feels great!
                      Gr2s w/ Raceland front end stuff. We are waiting on my 48x1.5 tap to shorten the housings without having to section and weld. For now a spacer to make up the space at the bottom of the strut
                      -NICK
                      • Andy.B
                        • Sep 2011
                        • 1650
                        #266
                        I've thought about that method before, but didn't want to put the money down on a tap and then not manage to get it to thread properly. My concern is that it will take quite a bit of force to cut new threads that big.
                        Let us know how that works out. If it taps easily, I would be interested in buying/renting the tap when you are done. That would make the job worlds easier!
                        • lowerstandards
                          • Oct 2013
                          • 30
                          #267
                          So... I'm lazy an don't want to read all of this, haha. Can someone give me some quick info on how/and or if it works for the front?
                          Thanks
                          1991 Alpine White 318i M52 Swapped
                          • ToPLeSS(e30)FeinD
                            • Jul 2011
                            • 2813
                            #268
                            works for the front, you have to cut the housings 2 inches, order toyota mr2 rear shocks, and run your coils with some 5-6 inch springs and everything will be alright..
                            '89 Delphin 2.8 Cabrio
                            '94 Yamaha FZR 600
                            Originally posted by FlexdXJ
                            Is that thing on air?
                            • cody_eppler
                              • May 2013
                              • 38
                              #269
                              Hey so I bought the mr2 front shock and also the camaro rear gas adjust shocks. I read all 18 pages and it seems to be really scrambled with info. I also have the GE coil overs. Ive been looking to see what I need to make my shocks fit with the right spacers for each shock.
                              -Thanks Cody
                              • Mr. Tasty
                                • Jul 2011
                                • 3421
                                #270
                                -Thanks Cody
                                mr2 fronts =2 inches shorter. You can cut your housings down 2 inches and run without a spacer.
                                (Daily Driver)
                                KW V2 Coilovers
