Vert/M3 swaybar question.
  • benz-tech
    • Jan 2011
    • 382
    I'm looking to keep my car balanced but would like a little flatter cornering. Current setup: '91 318i sedan, H&R sport springs for a 325i (xxxx6) Billy sports, E90 drop hats, No rear pads to loose the rake. 16x8 w/ not overly sticky tires. stock sways F&R. Used as a Daily driver
    What I'm thinking of doing: Vert front 21mm and M3 14.5 rear bars. M3 offset bushings- should do this soon because PO put the stockers in wrong.
    My big question is about the sway bars- anyone with that combo? do you think it would still be balanced?
    Right now it is pretty well balanced but it will push slightly at the limit, I'd just like a little less lean.
    You say "Where are your other two cylinders?"
    I say "Where's your other camshaft?"
    Frankenmotor: if an M42, M44, M20, S50, and S52 were to have a kid.
  • acolella76
    • 2950
    If you want flatter cornering, ditch the H&R sports. I have the 21mm front and no rear sway and love it. The back end never steps out anymore.
    -Alex
    • benz-tech
      • Jan 2011
      • 382
      I like the ride quality of the H&R sports - I went with the 6cyl springs so they'd be a good compromise between 'race' and stock. If I just ad the 21mm ft bar, my well-balanced car will push like a Honda FWD
      • 801coppertop
        • 293
        What is the advantage of running no sway in the rear. I just dont understand why it would be there if it is not needed?
        • blefevre
          • Dec 2008
          • 4287
          I have H&R sports, Billie Sports, Vert/M3 sway bar combo. On the street it's great. On the track there is still a lot of lean, which is from the H&R sports. It has slight oversteer, but I don't have the stickiest tires for the track.
          - E30, DSM, Golf R, Mazda 3 Skyactiv
          • SkiFree
            • Jun 2011
            • 2766
            No rear bar will equal more understeer.
            The stiffer you make one end, the more weight transfer will occour at that end. (this is a gross assumption but it works well as a basic rule). by removing the rear bar you will soften the rear end forcing the front end (which is already overloaded) to take more weight transfer which could/will give you more push. This in turn will give you more understeer. You'll find this more typically on autocross cars (and the opposite [big rear bar, little front] on drift cars).
            For street it just depends on one's personal preference, though some prefer the driver feed-back you get with more understeer (kind of makes you 'feel' quicker turning into an on-ramp).
            Hope that helps.
            ADAMS Autosport
