I'm getting some steering wheel shake any time I drive, no matter what the speed. Is it time for new tie rods/end links? TIA.
Steering Wheel Shake
Tags: None
Grab a flashlight and a screwdriver, poke it in your control arm bushings and pull a little on the rubber, they are likely shot.Comment
check your calipers had my front ones seize up on me and that was the cause of my stering wheel shakingComment
It turns out that my driver's side front tire was wearing unevenly. I could see cords on a section of it, so I put on the spare and no more shake. I'm still going to check all the other things you guys mentioned, though. Thanks for your help.Comment
did wheel weights get knocked off that wheel? if not, check your suspension on that side.sigpic
'91 325i 2-door, sterling silver over black, 14" basketweaves, stock for now.
'92 Miata, red, boss frog double hoop roll bar, full power flex poly bushings, tokico 5-way adjustable coils, front strut brace, '96 1.8l swap, '96 brakes, turn signal intake, cheapo 15" 5-spokes. vlsd, no ps, no abs, no pw, no pl, no BS car. only has ac as a factory option. somewhere around 300k on chassis and trans and 180k on engine.
