Maybe it's just me... but I don't see the point in buying JOMs just to buy shortened shocks and housings? Seems you could just buy the shortened shocks and GC coil over conversion for.. the same price?
How to Modify front JOM coilovers to go lower?
Originally posted by acolella76 View PostMaybe it's just me... but I don't see the point in buying JOMs just to buy shortened shocks and housings? Seems you could just buy the shortened shocks and GC coil over conversion for.. the same price?
My bilstein sport fully compressed was about 1/2" shorter than a fully EXTENDED short body. Which of course means like 90% of the shock travel can be utilized with the shorter strut insert rather than like 10% of the stock length strut.
In short, do the right thing and section your housings instead of wasting your money on a setup that WILL fail. Support a forum vendor and buy the GC setup. You cant go wrong.
Taylor
yeah, most of you guys either dont have JOMs or have problems if your laying your oilpan on the ground with just JOM coilovers. I have mine spun all the way down and have atleast 3 inches from my oil pan, on stock bottlecaps with the right size tires. I also have a 4 or 4.5 inch spring for the back and with the adjuster all the way down its even. I believe its a 60mm or 2.5 ID spring(there basically interchangeable)
INSTAGRAM @ merlow_
Originally posted by CHIF8008 View Post^ easy fix to the oil pan problem, just raise your motor till the pan sits level or higher than the sub-frame. then- install a skid plate that not only protects the oil pan, but also the steering rack, sub frame & the sway bar from ever getting caught on something.
all of this and you can achieve this:
NOTE: this is with 195/60 R14 size tire. so with the proper wheel setup you can be even lower. IM the guy that did the "method B" for modifying the JOM's"Do what you love, and love what you do" -Ray Bradbury
Originally posted by E30ruben View PostHow on this mother planet can you raise the engine up? Spacers on motor mounts? LOL
If you want more pan clearance, go m10 or m30. thats the only real way you wont cause any unwanted problems with more pan clearance.
Taylor
Originally posted by acolella76 View Postyou know the fronts go low as FUCK right? When installed correctly the oil pan will hit the ground before the adjusters are all the way down. Not sure why anyone would need to go lower...
The back sucks. I don't run adjusters or pads and it's about 1/2-3/4" above the tire. Going to buy new springs for the rear anyways since the rates suck
hes saying if you gonna buy shorter shocks and chop you housings with joms it would be like the same to do it with gc. the gc kit is about the same price of joms but doesnt include shocks but if you gonna do shorter struts on joms why not get the better springrates available with gc setup?Shawn @ Bimmerbuddies
Bimmerbuddies LLC
717-388-1256
2971a Roundtop Rd, Middletown PA 17057
bimmerbuddiesllc@gmail.com
Originally posted by SmokeE30 View Posthes saying if you gonna buy shorter shocks and chop you housings with joms it would be like the same to do it with gc. the gc kit is about the same price of joms but doesnt include shocks but if you gonna do shorter struts on joms why not get the better springrates available with gc setup?
