How to Modify front JOM coilovers to go lower?
    Ive heard its been done, and it gives much more adjustability, but how exactly is it done? Any extra info or a write up would be great especially with some pictars
    INSTAGRAM @ merlow_
    Its easy, cut off your lower spring perch, from there you have two options, either
    A) cut it all the way down smooth with the strut tube, then weld a circle at the desired height (essentially a new perch for your adjuster) and rock it. or...
    B) Simply trim the lower perch down to just the weld, and use it as your perch, guessing it'll gain you about 1/2 to 1 inch extra play.
    This guy did method B.
    Ground control actually makes a weld on perch, if you feel the need to have something more stable than a weld holding your spring up. Its my recommendation to get the perch from GC for safety reasons.
    My Build Thread Here (E30) ---> http://www.r3vlimited.com/board/showthread.php?t=240528
    And Here (2002tii) ---> http://www.r3vlimited.com/board/show...35#post3173435
      Anything for the back, other than removing the spring pads? I might get some but i'm worried about my early arches and the back being too high.
      1992 Mauritiusblau Vert
      2011 Alpinweiss 335is coupe
      2002 540i/6 Black/Black
      2003 GSX-R 750 (RIP)
        A lot of people don't even run the adjusters
          you know the fronts go low as FUCK right? When installed correctly the oil pan will hit the ground before the adjusters are all the way down. Not sure why anyone would need to go lower...
          The back sucks. I don't run adjusters or pads and it's about 1/2-3/4" above the tire. Going to buy new springs for the rear anyways since the rates suck
          -Alex
            ^ easy fix to the oil pan problem, just raise your motor till the pan sits level or higher than the sub-frame. then- install a skid plate that not only protects the oil pan, but also the steering rack, sub frame & the sway bar from ever getting caught on something.
            all of this and you can achieve this:
            NOTE: this is with 195/60 R14 size tire. so with the proper wheel setup you can be even lower. IM the guy that did the "method B" for modifying the JOM's
            -FREEDOM- is cruisin at 80, windows down and listening to the perfect song-thinking "this is it"
            -The Beauty in the Tragedy-
            MECHANIC SMASH!!- (you all know you do it)
            Got Drop?? ;-)
            But of course
            E30s are know to be notoriously really really really ridiculously good looking
              Oh yeah I wouldn't run adjusters, but I guess i'd buy 4 or 5" springs to get it low enough. I found some TC Kline springs on cl for $100, but he didn't email me back about them yet, and I have yet to find a pic of how just the springs (not their coilovers) sit...anyone have any idea? I think it's like a 60mm drop in the front, no clue about the rear though..
                not to go offtopic but will these be lower than GCs?
                  a 4 in spring will let the rear sit proper for early body e30s
                  Got Drop?? ;-)
                  But of course
                    4in seems like it will be crazy low, unless you can get them to work with the JOM adjusters.
                    -Alex
                      Do either of these methods require a new shock? Also how much are the weld on perches from GC?
                      INSTAGRAM @ merlow_
                        Measure the JOM adjusters and i'll get you the springs you need.
                        Here is a car with 4" springs
                        And here is another on the lowest setting with undersized tires.
                        www.gecoils.com
                          First: GC some sell you the perches separately unless you've purchased an entire kit from them before. I know. Stupid.
                          Second: there Is no reason to go lower than the stock perch weld. That kit is already known for blowing struts quickly and you want to go lower?? At some point you need to do things correctly to achieve the desired result as well as a setup that will hold up for a long time.
                          Go with shortened housings and short body shocks. There is absolutely no reason to go lower than what shortened housings will allow for. If I lower my adjusters all the way down, I will set the motor on the ground before the suspension even settles.
                          Also, with the car that low I hope no one plans on doing anything but driving in a straight line because turning your wheels will be almost impossible
                          Taylor
                            Also, I have 5" springs in the rear with thick poly spring pads top and bottom and I have credit card clearance. I realize I have late model arches but with JUST a spring I can tuck wheel no problem.
                            Taylor
                              Your pan will never touch the ground with JOM's or any other coilover unless you section out the housings like Taylor mentioned lol.
                              Sounds more like worn out motor mounts and other suspension bits.
                              1991 325iS turbo
