Since mine are completely cracked, would it be beneficial to replace them with the m3 style bushings or just use the default bushings? Pros, cons, etc... Note I have an 88 325i vert.
Judging by your sig your car is pretty stock. You'd be fine with stock replacements and they're super cheap. Another option is using E36 non-offset bushings, they are a little more solid. It wouldn't hurt anything to install the E30 M3 bushings though, they're only about $40-$45 for a pair. You'll want to get an alignment if going with offset.
BimmerHeads Classic BMW Power Delivered Worldwide
Grover Beach, California BimmerHeads.com
The offset bushings will increase caster, which will make the car more directionally stable at speed. As stated above, front toe will need to be reset after installing the offset bushings.
So the e36 non-offset bushings would be the best I assume, but for the price get the stock bushings?
