how do i remove tie rod ends?
  • peytonracer4
    • May 2011
    • 524
    i'm stuck. i can't remove them. i loosened the clamp but i can't seem to get it off. i tried heat and wd 40
  • Balleristic31
    • Aug 2009
    • 4198
    One wrench on inner tie rod square section and one on the tie rod ends. They may have seized up in there so go hard on them lol
    -NICK
    • S62
      • Nov 2011
      • 262
      You can't remove the tie rod that connects to the wheel hub? I don't really understand your question.
        • 37832
        He's trying to removing the outer tie rod from the inner tie rod.
        It unscrews as Baller said above.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
          In most cases, if there is wear in the outer tie rod ball joint, there is also wear in the inner ball joint, meaning that replacement of the entire tire rod (and bellows) is indicated.
          • S62
            • Nov 2011
            • 262
            try getting a wrench on it and then hitting the wrench with a hammer
            • peytonracer4
              • May 2011
              • 524
              yeah i tried this. i can't get enough force on it to get it loose no matter what. ugh
              • taiden
                • Oct 2009
                • 178
                I grabbed mine with two vice grips and wiggled them back and forth until they broke loose. Took probably 15 minutes of muscle. Then I would back out the tie rod end say a 1/4 turn, and then the opposite way 1/8 turn, forward 1/4 turn, back 1/8 turn. After doing this for another 15 minutes my tie rods are mint and can be adjusted (or removed) easily
                • mccor023
                  • Jul 2011
                  • 683
                  I was in the same boat last week. I tried all methods described. Had you use blaster for 3 days while trying the vise grip move. It took me awhile to break them free, but finally got them out.
                  I love that people ask stupid questions so I dont have.
                  • taiden
                    • Oct 2009
                    • 178
                    also worth hitting the threads with an aggressive wire wheel too if you can. Once it starts moving it makes the rest of the work easier
