K-mac Camber Plates
  • Taylor
    • Oct 2005
    • 8
    K-mac Camber Plates
    Hi All.
    Looking at some camber plates for my E30. I live in Australia where there is a company called K-mac suspension that provide an adjustable camber kit for the car. Just wondering if anyone has got a set and what their thoughts on them are.
    Cheers
    T
  • Bavarian3
    • 1230
    There are better choices out there....
    How much do you want to spend?
    • Taylor
      • Oct 2005
      • 8
      I have been around a couple of places but everything seems fairly similar in Australia. Around about $300 plus fitting. The problem is that I have substantial negative camber on the rear tyres due to the previous owner lower it. What are my solutions to getting rid of this??
      Thanks for your help.
      T
      • CorvallisBMW
        Long Schlong Longhammer
        • 13039
        negative camber on the rear cannot be corrected by plates, you have to use eccentric trailing arm bushings. I think the Kmac plates are pretty good, unlike many other solid steel mounts they use urethane so they won't be as harsh. But maybe someone else can chime in and give their opinions.
        • Taylor
          • Oct 2005
          • 8
          I have been able to source some adjustable offset bushes for the rear from K-mac however what I was wondering was whether this was the best way to go??
          Thanks
          T
          • JeffBij
            • 65
            The rear adjustable KMacs have a bit of a reputation for not holding their positions over time. I know several people with track cars where the KMacs have moved or failed over time.
            I can recommend a set that Bimmerworld sells. Have been on my E30 track car for 3 years now with no issues. They are running $229 USD for the steel core model. (I think they maybe mfg by Powerflex, but not sure.)
            www.bimmerworld.com
            Jeff B.
            Roanoke, VA
            1989 325i track prepared
            2000 328Ci daily driver
            Jeff B.
            Roanoke, VA
            1989 325i Track/Race prepared
            2000 328Ci Daily Driver
            1989 325i being restored
            1987 325is being stripped for parts
