differece between 318i springs and 325i?
  • MikeM10
    • Sep 2011
    • 19
    I have an early 318i with drum brakes in the rear and i plan on swapping all four brakes with the 325i brakes. vented rotors i the front and disc brakes in the back. I know that im going to need to get the trailing arms off of a 325i to make it work. Id also like to get some lowering sprngs from bavauto to give it better handling, i just dont know if i should order springs for325i or 318i. is there any differences in them?
  • taiden
    • Oct 2009
    • 178
    Go with what's made for your car.
    • Hey_You
      • Nov 2009
      • 963
      325i springs made to handle a m20, 318i springs made to handle a m10. I think the spring rates are a bit different.
      85' 318i ~The Bronze Bomber (FrankenM10 with a Forced Future :wgaf:)
        • 37829
        They will be different but of course 325 springs will work. If you run 325 springs you'll likely end up with less of a drop and a firmer ride than the same spring would give you if it were spec'd for a 318.
        Classic BMW Specialists
        Grover Beach, CA
        www.BimmerHeads.com
        • S62
          • Nov 2011
          • 262
          Why are you choosing bav auto springs?
          • irish44j
            • 2763
            don't forget you'll also need new e-brake cables for the rear discs when you do the conversion.
            Stage rally/rallycross e30 build/competition journal
            Track/street e21 build
            visit Condor Speed Shop
            visit Motorsport Hardware
            [FONT="Franklin Gothic Medium"] 1985 318i/M50 Rally Car - 1988 Porsche 924S - 2005 Sequoia tow pig - 2018 GTI
