might want to do a lift
  • devon.818
    • Feb 2011
    • 2937
    so i will possibly be trading my low n slow vert for a early eta car.
    was planning to use it as a beater, but the thought of putting a minor lift on it and taller tires keeps crossing my mind.
    anyone have advice on how to do this? how could i get some stiffer springs that wont lower it?
    how can i raise it up?
    thanks
  • FunfGan
    • Jan 2011
    • 4958
    Could always weld the stock perch of higher and run a shock spacer in the front, and find a spring from another car that works in the rear?
    Go here be happy!
    Ratchet Garage e30 V8 build.
    • CW325
      • Jul 2011
      • 1434
      Vert springs?
        • 37833
        Easiest way is to make a spacer out of a hunk of metal that goes between the top of the front strut mount and the bottom of the shock tower. I am going to be making something like this for one of my E30 projects.
        For the rear, vert springs with thick or double pads. Another option would be E36 325 rear springs.
        You can only go about 2 sizes taller than stock with the tires without having clearance problems.
        Grover Beach, California
        BimmerHeads.com
