spring rate
  • immajackuup
    • Dec 2010
    • 1132
    spring rate
    well I just order 550LB front and 750LB rear,is that too much for dd???
  • ak-
    • 12422
    Yeap. It's all opinionated though. But yeap.
    1991 325iS turbo
    • immajackuup
      • Dec 2010
      • 1132
      but is it a good stiff or a bad stiff?
      • ak-
        • 12422
        What shocks are you using?
        It was a good stiff for me in the front with Sports but a so-so stiff in the rear with Sports.
        1991 325iS turbo
        • immajackuup
          • Dec 2010
          • 1132
          bc coilover,been in a gs300 with the same rate/coilover and it was smooth.
          I just know the j spring are 1k LB which is horrible stiff but good for track which I'm going to do.
          • ak-
            • 12422
            Well those are dampening adjustable.
            A different car, with different weight, with different rates is a different story.
            1991 325iS turbo
            • coreyw
              • Jul 2010
              • 368
              Nah, you'll be fine.
              S52 Swap
              Shtuff For Sale
              • ak-
                • 12422
                How old are you?
                1991 325iS turbo
                • immajackuup
                  • Dec 2010
                  • 1132
                  Originally posted by ak-
                  How old are you?
                  asking because of my bad grammar? :D
                  • ak-
                    • 12422
                    No I'm being serious lol. Assuming you're young, 550/750 won't bother you much.
                    1991 325iS turbo
                    • immajackuup
                      • Dec 2010
                      • 1132
                      no i'm being serious lol. Assuming you're young, 550/750 won't bother you much.
                      23,I used to have a civic with skunk2 coilover pair up with agx and it was harsh which I didn't like.
                      • ak-
                        • 12422
                        You'll be fine.. Just don't slam it on it's nuts like everyone else and lose all your shock travel; giving it a harsh ride.
                        1991 325iS turbo
                        • immajackuup
                          • Dec 2010
                          • 1132
                          Bc doesn't have that problem because it use the shock body instead of sleeve like ground control which isn't true coilover.
                          • ak-
                            • 12422
                            So you are going BC's.. And yeah I know, though it's still possible by adjusting the first collar like a "traditional" coilover. Also depends how short your spring is. I want to know how low(or spun high in this case) the shock collar goes. Nobody really ever clarifies in detail.
                            1991 325iS turbo
                            • immajackuup
                              • Dec 2010
                              • 1132
                              5.5inches in front and 4inch rear,cutting the strut housing to 1inch instead of 2 which will let me go another inch lower.
                              I'll let you know how things go when I receive my coilover.
