what is this liquid inside the struts?
  • peytonracer4
    • May 2011
    • 524
    i just took my shocks out of the front strut assembly. there was a bad smelling goo inside the assembly. almost like the shock was leaking. however the shock looks to be in good condition on the outside.
    do you think it was leaking, or is it something they put in there from the factory to keep the shock from rusting.
    There is a school of thought that putting oil in the strut housings will help with heat transfer from the strut cartridges. I think it just makes a mess. That liquid could be an oil added or it could be fluid from a leaking strut. Kind of hard to know which it is at this point.
    • einstein57
      • Jun 2007
      • 10780
      If its a standard insert its oil. It does aid in cooling as it acts like a thermal conductor. If your running an inverted Bilstein DO NOT ADD OIL!!!!!!!
      www.gecoils.com
      • TobyB
        • 5242
        yeah, 5 out of 5 stock struts I pulled apart last weekend had it in 'em.
        It does stink...
        t
        • Farbin Kaiber
          Lil' Puppet
          • 29502
          I've been told its called BluntCum.
          • S62
            • Nov 2011
            • 262
            Are Bilstein Sports inverted??
            • CW325
              • Jul 2011
              • 1434
              yes
              • S62
                • Nov 2011
                • 262
                Originally posted by CW325
                yes
                Shit, I added a bit of oil. What can happen?
                • MikeDE
                  • 1873
                  oops
                  -03/2005 E46 330D Touring 6spd(204hp/410nM) Sapphire Black/Naturbraun Sport...300k KM & 35mpg(mixed)
                  • S62
                    • Nov 2011
                    • 262
                    Originally posted by MikeDE
                    oops
                    Whats the worst that could happen?
