Can I remove front spring pads?
    • 37829
    Can I remove/rip out the front spring pads without pulling anything apart?
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • 34839
    you could cut them out if there is enough slack in your springs. obviously you'd have to jack up the car..
    • UNHCLL
      • 8790
      douse them with lighter fluid, and set them on fire while mounted to the car.
      Sure fire way to get them out! ;)
      Below the radar...
      • Sean
        • 5793
        In all seriousness, yes. The paint on your springs will scratch off a little bit though.
        I don't have any pads up front.
        - Sean Hayes
          • 37829
          Eh, jacked it up and there's just not enough slack to rip em out.
          Oh well
          Grover Beach, CA
          www.BimmerHeads.com
          • 2002maniac
            • 4260
            Use a spring compressor. Should be easier than removing the strut.
              • 37829
              Good idea. I'll do that, probably next month or somethin
              Grover Beach, CA
              www.BimmerHeads.com
                • 37829
                I did pull out all of my rear spring pads today, dropped it down about 3/4 inch. Much better.
                Grover Beach, CA
                www.BimmerHeads.com
                • f u z z
                  • 1600
                  spring pads are for the weak.
