spring question
  • A_325i
    • Jun 2005
    • 680
    spring question
    on my eibachs they say 29/99 what does that mean? and what is the spring rate of the eibach prokits?
  • Mystikal
    Wheel Fitment Expert
    • 9602
    Just a random part number.
    Rates are 148F 275-343R. Basically stock but shorter, brilliant Eibach engineers.
    • A_325i
      • Jun 2005
      • 680
      i dont know man its nothing like stock the front of my car is ummm extremely stiff my buddy who is 240 pounds sat on my front fender and the springs or shocks did not compress at all they are EXTREMELY stiff the rear is a bit softer but still very stiff and the ride is very harsh
      • Mystikal
        • 9602
        That's called being on the bumpstops. You have no suspension.
        • nefarious7907
          • Jan 2005
          • 1170
          With new suspension, or old suspension with oil running down the shocks and cracks on the springs because someone torched them.
          http://www.cardomain.com/ride/657387
          • A_325i
            • Jun 2005
            • 680
            hmmm
            so...uhhh what does that mean? the shocks are bad? wtf do i do to fix it
            • Digitalwave
              is a poseur
              • 6299
              Haha, Eibach Pro Kit springs are some of the softest springs you can buy. My friend has them on his 84 318i which is light as balls and I thought it still had stock springs it was so soft.
              RISING EDGE
                • 37832
                A friend of mine had them on his 88 iS and as said, they're pretty much just like stock, but lower
                Classic BMW Specialists
                Grover Beach, CA
                www.BimmerHeads.com
                • A_325i
                  • Jun 2005
                  • 680
                  ok so something is wrong with my suspension then
                  • Mystikal
                    • 9602
                    hmmm
                    Your dampers are doing nothing, essentially the only thing holding your car up and controlling the body motion are those bumpstops. Your handling really cannot get any worse, and you are quickly tearing apart your strut towers, and in the long run the whole car.
                    To fix it, buy shorter dampers (Konis are a good start) or proper springs (H&R Sports, IE Stage III's, etc).
                    • A_325i
                      • Jun 2005
                      • 680
                      bilstein sports (apparently revalved....i thought bilsteins were shortened to match lowering springs? i sure as fuck dont have the money for konis
                      • nefarious7907
                        • Jan 2005
                        • 1170
                        they are shorter, but some like the H&R bilstiens are perfectly/RFC matched to their springs. Its probably the same with bilstein the probably sell springs that are closey matched to thier shocks but bilstien sports generally work great with any shorter spring.
                        • Digitalwave
                          is a poseur
                          • 6299
                          H&R shocks aren't Bilsteins.
                          A_325i, I doubt yours are revalved.
                          RISING EDGE
                          • Mystikal
                            • 9602
                            Honestly, stock Billy Sports' end of travel is about your ride height.
                            • Digitalwave
                              is a poseur
                              • 6299
                              Mine? I am aware of this :) My fronts are revalved though.
                              RISING EDGE
