Choosing shocks for lowering
  • Rc 415
    • Jun 2011
    • 723
    Best shock for lowered on high spring rates
    I'm trying to decide what my best choice would be for shocks on my car. I have a German engineering Coilover setup with 450/650 rates, I'm going to lower the car but not slam it. I've read about using ix shocks and g60 shocks but I'm not sure. I'm currently looking at a set of konis but I don't want to bottom them out. Any help here?
    1987 Delphin 325IS
    LS1•TSP 228r• condor speed shop solid subframe, diff, fcab, mounts•Airlift air ride suspension•e36 ps rack•Eibach sways•16" Spal puller•bbk 310mm front & rear•17" BBS RS•
    Build Thread
    1993 alpine 2 325IC
    •Ground control coilovers•16" BBS RS• momo woodgrain
    • 37829
    Are you shortening the housings?
    If not, go with Bilstein Sport or Koni Sport.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • Rc 415
      • Jun 2011
      • 723
      I'm not shortening the housings
      1987 Delphin 325IS
      Build Thread
      1993 alpine 2 325IC
      • E30_fiend
        • Apr 2006
        • 7348
        then get stock length koni's or bilstein sports.
        I recommend shortening the housings and going with short body shocks.
        Taylor
        • acolella76
          • 2950
          How low do you plan on driving the car? If you want it anything lower than half way down the spindle, then you will be riding pretty uncomfortably. Shortened housings are the way to go.
          -Alex
          • einstein57
            • Jun 2007
            • 10780
            If you go with bilstein sports make sure you cut the bump stops.
            www.gecoils.com
            • Rc 415
              • Jun 2011
              • 723
              I just want to eliminate the wheel gap. Nigel is there anything in specific you'd recommend running so as to not bottom out the struts?
              1987 Delphin 325IS
              Build Thread
              1993 alpine 2 325IC
              • ak-
                • 12422
                1991 325iS turbo
                • einstein57
                  • Jun 2007
                  • 10780
                  I run bilsteins on most of my cars except for the one with the KYB AGXs. Although I've been sectioning all my strut tubes. The diesel is probably going to be next.
                  www.gecoils.com
                  • Rc 415
                    • Jun 2011
                    • 723
                    Okay so what's the best option front and rear if I section the tubes and how much is recommended be cut out?
                    1987 Delphin 325IS
                    Build Thread
                    1993 alpine 2 325IC
                    • einstein57
                      • Jun 2007
                      • 10780
                      I'd say ix inserts up front with a 1.5" section and camaro rear shocks. You will scrape your frame rails before you bottom out the suspension.
                      www.gecoils.com
                      • Rc 415
                        • Jun 2011
                        • 723
                        And the shocks valving is good with the high spring rates?
                        1987 Delphin 325IS
                        Build Thread
                        1993 alpine 2 325IC
                        • acolella76
                          • 2950
                          With your rates you will be at the upper limit of the shock's valving, but yes the valving is good.
                          -Alex
                          • ak-
                            • 12422
                            I'd say ix inserts up front with a 1.5" section and camaro rear shocks. You will scrape your oil pan before you bottom out the suspension.
                            1991 325iS turbo
