Megan Racing Coilover Install
  • FLG
    • Sep 2011
    • 3165
    #31
    I'd go 8k front and probably 12k rear or 10k front 12-14k rear
    Like my 8k fronts but 10k rears are a tad soft
    Also running a larger rear sway bar
    Sent from my Galaxy Nexus using Tapatalk 2
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • chrisbmx68
      • 358
      #32
      Supposedly the stock valving can handle + or - 2k in either direction without needing to be made custom.
      • TehPilot
        • Mar 2012
        • 207
        #33
        I'm confused on why these coilovers needs to be welded to the upright?
        Nick
        Why have American muscle when you can get some German blow?
        instagram - tehcapo
        • chrisbmx68
          • 358
          #34
          Because e30's don't have removable knuckles/spindles like most cars. The stock strut tube with spring perch is welded on OEM
          • Rubes
            • 295
            #35
            How can I get my rears lower? I pretty much bottom out everything.... From the rear sleeve and I took out the adjusters
            • FLG
              • Sep 2011
              • 3165
              #36
              Remove everything from the rear. Just have the springs no pads or adjusters
              • chrisbmx68
                • 358
                #37
                Bc and i assume meagan as well sell shorter rear springs with whatever rates you want. I leave the pads in the rear to help securely locate the spring and adjuster but plenty of people dont.
                • HugsBmw
                  • Oct 2009
                  • 73
                  #38
                  If you see that your wheel bearings need to be replaced soon will it be a good idea to weld the 360° on the knuckle? Im assuming it will be a pain to do the job.
                  • ohlaud
                    • Nov 2013
                    • 183
                    #39
                    nice write up man! ill def be looking into these
                    • chrisbmx68
                      • 358
                      #40
                      Welding all the way around would be ideal if possible. That being said I have close to 20k miles on them at this point without issue I don't believe it's unsafe to not weld 360 degrees. I also have decided to step up to 8k front 10k rear rates going with a slightly shorter rear spring than stock if I hadn't done a m50 swap I would still be content with the softer rates and m42.
                      • Jdesign
                        • Jun 2012
                        • 198
                        #41
                        So does this mean you bought new springs to make the rear 10k?
                        • chrisbmx68
                          • 358
                          #42
                          Correct I am using the OG front 8k springs that came with the coils, and new rear 10k springs.
                          quote from BC (contacted them instead of megan seemed easier, and the coils are identical from what I can tell)
                          "To get the desired rate in the rear , we would have to change up the spring type from S-barrel to linear. The standard length for the rear spring is 160mm. If you wanted to move up to 10k or 12k we would also need to drop the length of the spring . The 10/12k is available in either a 140mm or 120mm length depending on your preference.
                          Replacement springs for a pair of 2 is $100 plus shipping to your location."
                          If you wanted to order different rates just call them up and tell them you have their e30 coil overs.
                          BC RACING NORTH AMERICA
                          1-321-206-6381 TEL
                          1-800-741-1972 FAX
                          • Jdesign
                            • Jun 2012
                            • 198
                            #43
                            Awesome!! that is super helpful. I am going to buy a set of Megans but I know from reading around that I am gonna want/need stiffer rates.
                            • FLG
                              • Sep 2011
                              • 3165
                              #44
                              Bc also revalves the shocks to match the spring rates. Why not just get from bc?
                              Sent from my SCH-I545 using Tapatalk 2
                              • Jdesign
                                • Jun 2012
                                • 198
                                #45
                                That's what it looks like I might just do. Any good suppliers/ suggestions to buy from?
