OK here is my z3/e36 rack conversion list...missing anything?
  • nickmp0wer
    • 1427
    the rack (got a 80k z3 rack with a bent tierod for $110 shipped btw)
    linkage to from the colum to the rack. I will be using the early 318 linkage since i have an airbag car
    Lines. I hope one of my non high pressure lines since i will be not be running power steering. Hopefully i can use it how i alreay have it rigged up with the resivior
    tierod locking washers so i can use my old tierods
    Spacers. Should i just use washers or cut some pipe or what? anyone know how long?
    am i missing anything?
    I might also try to make some steering stop things so my tires dont rub
  • erik325i
    • Jan 2005
    • 3567
    You will also need to shorten the steering linkage by using an assortment of nuts, bolts, and spacers. I have the complete parts list from Zionsville if you want it.
    Also, why are you not going to use power steering?
    • nickmp0wer
      • 1427
      im not using power steering becuse i think the e30's is way over boosted and i really like how it feels with out it.
      with the linkage im going to do what jordan did in this thread http://www.r3vlimited.com/board/show...+steering+rack
      • jajou318
        • Jan 2005
        • 1023
        way off topic but nick are you still messing around with the ITB idea?
        • nickmp0wer
          • 1427
          yeah, i just need some time when i can not have a car for a little while
          • nickmp0wer
            • 1427
            i stopped by les schwab to see if the steering rack they installed on the car came with new tie rods. They said it only came with the inner ones. The z3 rack came today and guess what? the tierod that was bent in an inner one!!! anyways the rack seems to be in great shape, very tight, and is in fact 2.7 turns
            also after looking at it more, the outer tierods seem to be nearly new
            • ///M42 sport
              • 3952
              Is tire rubbing a problem once you install the z3 rack?
              • DEV0 E30
                • Oct 2004
                • 8903
                Why don't you want power steering on a rack that could easily have it?
                Fuh raze factor?
                • 2002maniac
                  • 4260
                  Fuh raze factor?
                  feel. My power steering worked fine. I removed it becuase it makes the car that much more fun to drive. The steering is much more communicative without it.
                  • nickmp0wer
                    • 1427
                    no, my wheels currently rub at extreme turning angles
                    • Jonathan M3
                      • 1837
                      The standard e30 rack is pretty easy to drive w/o power steering because its such a low ratio, but you may find the z3 rack to be alot harder to turn w/o power assist.
                      '05 E46 M3 Imolarot/Cinnamon - CURRENT
                      '98 E36 M3 Estorilblau/Dove - SOLD
                      '90 E30 M3 Brilliantrot/Black - SOLD
                      SRS BSNS Motorsports - 24hrs of LeMons Racer
