Is my rear suspension dying?
  • uflnuceng
    • Apr 2005
    • 1049
    My E24 just seems to keep falling on its face, even from something as simple as a 3000 rpm drop. I can feel my rear end vibrate up and down and then I finally get traction and the car just flops. However, when I push on the rear suspension, which the PO told me was fairly new, I get plenty of resistance. When the E30's original suspension was dead I could push the rear end of my car up and down with no problem.
    Anything else I should look at here? I even had a spare tire in the trunk but I couldn't seem to get the rear end traction I needed.
  • Digitalwave
    is a poseur
    • 6299
    Sounds like classic wheel hop. Do E24's have semi trailing arms like E30's?
    You might want to freshen up all the bushings in the rear.
    RISING EDGE
    • uflnuceng
      • Apr 2005
      • 1049
      Their setup is identical to E30s as far as appearance goes. different trailing arms most like, but similar type of setup.
