Rear shock mounts.
  • SebSter
    • May 2004
    • 192
    Rear shock mounts.
    Brand new e30 rear shock mounts lasted me a whole 2 weeks before the mount actually tore through where it supports the shock and the car was just bouncing freely with no shock to hold it in place.
    I fixed it up to hold and its drivable and sturdy but it rattles a little bit. I dont want to buy the e30 ones they'll just give again in a matter of weeks. Are there any reinforced aftermarket ones that will last me a little longer? Someone told me that e46 rear mounts are the same as on e30s and will fit on and are much more durable. True?
    Any ideas?
    1990 325ix
  • I_like_E30
    • Oct 2004
    • 87
    i need to replace mine too, and looking for good, better then e30 ones....
    • E30 Wagen
      you probably installed them wrong? They should have lasted more than two weeks.
      Check out meyle heavy duties, or urethane setup if you're that concerned. I've had meyle heavy duties for ~4 months, no problems...
      • Digitalwave
        is a poseur
        • 6302
        E46 Cabrio ones fit and are said to be stiffer, but if you tore through a brand stock mount in 2 weeks you must have some insanely stiff suspension, and you might want to look at some billet mounts like GC or JT Designs. They are about $100 for a pair and have a lifetime warrenty.
        RISING EDGE
        • AdamF 88iS
          • 2051
          JC Designs. Stay away from GC mounts.
          Adam Fogg- '88 M3
          Common sense- It's the new 'gifted'
          • NC325iC
            • Mar 2004
            • 6565
            why no gc?, they look pretty beefy
            tms sells some that have a lifetime warranty that are still rubber bushed
            • e30sd
              Fistee
              • Jan 2004
              • 5517
              cant use a rear strut bar (not that it matters) with the gc ones. plus i've seen them bend shock shafts. awesome!
              • golde30
                • 11464
                LOL~!
                which ones can u run a rear strut bar with that are also nice and stiff?
                IG: @Baye30
                • NC325iC
                  • Mar 2004
                  • 6565
                  ...yeah i really care about rear strut bars... they make what one for the cabs... whats recomended, id like to pay no more than 90 for a nice solid set
                  • AdamF 88iS
                    • 2051
                    GCs rear mounts use too stiff of a urethane in the center. The shock needs to be able to swing back and front a little bit as the suspension travels and with too stiff of a mount it will tweak the shock shaft. The JTD mounts are billet but have a softer compound in the center.
                    Adam Fogg- '88 M3
                    • NC325iC
                      • Mar 2004
                      • 6565
                      there we go thanks man
                      • Mystikal
                        Wheel Fitment Expert
                        • 9602
                        Been running GC rears for a couple years now, no problems.
                        I see what Adam is saying and would heed his advice though.
                        • Dave
                          E30 RAT
                          • 11675
                          Where is a good place to get the JT Designs ones?
                          Current Cars
                          2014 M235i
                          2009 R56 Cooper S
                          1998 M3
                          1997 M3
