Questions questions questions
  • aPapester
    • 215
    information
    stay with me please, im learning, and on a cheap budget, not easy to start from scratch with no knowledge if i dont know what to look for, and please try to avoid suggesting a "better" route, just want to know if it works
    i want to get pretty low with these cosmo coilover sleeves and i would prefer to ask questions instead of experiment and get screwed
    im planning on shortening the strut housing, i have a 325e its an 85, stock stuff as far as i know
    so im going to cut the spring perch off, cut 2 inches of the strut housing, weld on a new perch for the adjustable sleeves, and maybe make a spacer if needed
    questions
    1. do i have 45mm housings or 51mm housings?
    2. which shocks could i use for the fronts?
    http://www.oreillyauto.com/site/c/de...0077&ppt=C0035
    is going to work as far as i know?
    3. then i need to get new bearings and push them into the strut mount
    6302-2RSJ fit perfectly
    corrrect?
    4. for the rear i would shorten just the same
    can I use camaro gas-a-just and use a spacer to fit the bolt?
    5. im using STRUT INSERTS from a 91 mr2 for the front, and SHOCKS from a camaro(what year or years?) correct? i dont really know the difference
    6. if i wanted to run more camber, say in the rear, could i use http://www.e30tech.com/forum/showthread.php?t=80410 those to get more negative camber or would those only work for correction? what about in the front, what is a cheap way to get more camber, if any?
    let me know if im missing anything else i would need to do. any problems i could possibly run into
    thanks a ton
    Check Out My Photography
    aPapester Photography Facebook
  • Sagaris
    • Sep 2009
    • 2243
    Why do you want more camber in the rear? Are you having oversteer issues?
    • aPapester
      • 215
      just for looks, i dont know how much camber ill get when i drop it but im not going to go crazy numbers, just noticable
      • Sagaris
        • Sep 2009
        • 2243
        So the goal is to look like this
        and handle like this?
        Seems legit.
        If all you care about is looks and you are on a budget, why not cut the springs?
        (serious question)
        • aPapester
          • 215
          i already have coilover sleeves,
          but my goal isnt any different then alot of guys,
          i could just put the sleeves i have on right now but i will blow out my shocks and not be low enough.
          besides the point im just wondering if it WILL work,
          • aPapester
            • 215
            Bump for some actual help please
            • aPapester
              • 215
              Bump, wanting to do this project soon,
              • aPapester
                • 215
                Can someone help me out any?
                • mr ilia
                  • May 2011
                  • 582
                  Well, if you already have springs, then you need to buy some shocks. brows ebay for some basic dampers.
                  I have these in my car with a set of some unknown lowering springs.
                  http://www.ebay.com/itm/STAGG-4-SHOC...#ht_500wt_1413
                  • Farbin Kaiber
                    Lil' Puppet
                    • 29502
                    You should get together with the e30 guys in Boise at a BOE meet. They will talk with you, and give you a ride in a set up car so you know what to expect/want.
