325i vs 325ix SPRINGS
  • MattBimmer
    • 339
    Hey guys I am selling some springs to a guy with a 325ix and he is wanting to lower his IX a little bit. I have 318is springs but are they shorter than stock IX springs. Do I need to cut my stock springs to give the buyer a slight drop or can I sell them as is?
    • 34835
    They are likely the same length, just softer.
    You buyer would be better off cutting a dead coil off his ix springs.
    • MattBimmer
      • 339
      Well I read another thread where someone said the IX spring is 1 inch longer in the front, and the buyer also doesn't have the means to cut the coils.
      Also what is the best tool for cutting the springs?
        A cutoff wheel in an angle grinder.
          • 34835
          From what i recall ix springs are the same part # as 325e springs. They are definitely not longer.
          • MattBimmer
            • 339
            Alright thanks for the input and luckily I was wrong the Buyer has a 325I and his brother has the IX. Cutoff tool and angle grinder it is. One full loop from the top would be a good drop right or do I need to do a have coil from both sides.
              One coil from one end should be fine.
