how much travel do I have w h&r races
  • bastianshaw
    • Jan 2007
    • 2210
    running billy sports and no trimming is this an issue?
    is it generally recommended to trim w races?
  • E30_Pare
    • 7801
    Well if you never bottom out your suspension they you could have no bump stops. They're a safety measure incase you do bottom out. Without bump stops u would get a loud bang every time you max out travel.
    DREWLIENTE
    1$ PShops PM me
    • M-technik-3
      • 18946
      Realistically about 2.25 inches of travel.
      • Jaxx_
        • Dec 2009
        • 1880
        edit: fuck what I just said. basically I don't think it's an issue. I'm not running bumpstops. You'd have to be pretty damn aggressive to bottom out the car. (doing jumps?)
        • nrubenstein
          • 3148
          Have you removed the internal bump stop completely? The Bilstein bump stop is super long. Like, longer than the stock bump stop. Unless you have cracked open the damper and trimmed it, you are travel constrained.
          2002 BMW M3 Alpinweiß/Black
          1999 323i GTS2 Alpinweiß
          1995 M3 Dakargelb/Black
          - S50B32/S6S420G/3.91
          1990 325is Brilliantrot/Tan
          1989 M3 Alpinweiß/Black
          • Jaxx_
            • Dec 2009
            • 1880
            oh, I'm a dumbass then. I was thinking spring bumpstops.
            • bastianshaw
              • Jan 2007
              • 2210
              is it a good idea to open the shock nd remove?
              2.5" seems short ;-)
              • M-technik-3
                • 18946
                Have you put a stock spring beside a H&R race? They are drastically shorter and stiffer.
                • bastianshaw
                  • Jan 2007
                  • 2210
                  ok bumpin an old thread
                  I never opened my shocks and trimmed the bumpstops and as stated earlier im on races, the front end sometimes is kinda harsh is this me hitting the stops? i searched, so I know HOW to do it...seems to me billstein should make sport shocks that work w shorter springs
                  • LJ851
                    • 7919
                    I measured my H&R races and i have less than 2 inches up travel in the front. Im running konis although every E30 bumpstop is longer than 2 inches.
                    There a are a couple good bilstein bump stop writeups here on r3v, do you know how to search?
                    Lorin
                    The M30 is God's engine.
                    • bastianshaw
                      • Jan 2007
                      • 2210
                      do you know how to read?
                      • Earendil
                        • 1662
                        I see a single question mark, and not one that follows an answerable question. You are using far stiffer springs than stock, and the definition of "kind harsh" is hugely subjective, but certainly race springs are stiffer than stock. Now, is the harshness you feel the bump stops? We can't say for sure. You can either work some science, and mark your setup in a way that might indicate if you are ever compressing the suspension that far, or you can search more and read more to try and figure out if other people's experience and description matches yours.
                        My guess, running H&R Sport on the streets of Seattle, is that you aren't hitting the bump stops. You just have a stiff ride, and this in combination with your roads is harsh to you.
                        1989 - E30 - M20B25 - Manual. Approx 300,000+ miles - Track Rat & Weekend Fun
                        2000 - E46 - M52TUB28 - Manual. Approx 130,000 miles - [not so] Daily Driver
                        I'm looking for a Lachssilber Passenger Fender and Hood. PM if you have one or both to sell!
                        • bastianshaw
                          • Jan 2007
                          • 2210
                          when i say kinda stiff i mean bone jarring, suspension is bottoming out(wanted to confirm here) is seems like rubber wouldnt be that stiff
                          • Earendil
                            • 1662
                            $5 says the race springs are more jarring than proper stock rubber bump stops. Race springs are certainly stiffer.
                            • jeffnhiscars
                              • Jun 2011
                              • 6011
                              I had the same issue with my 84 318i with Sports & Eibachs. Cutting the bumps in half resolved it. I posted a DIY somewhere.
                              Alice the Time Capsule
