Rear wheel rate vs spring rate
  • TobyB
    • 5296
    Gustave says it's .45
    which seems a little low based on the real numbers I got from some stock car
    parts I used. But not out of the realm of believability- calculating the
    real rate of a 5" spring compressed in a vee is not trivial. Nor linear, it seems.
    Anyone here have real- world numbers they'd be willing to share?
    Mine: 600# 5" dia by 5 1/2" long spring gave a rate of 300# per inch at the wheel, measured with scales and a tape measure. 200# preload, 7" to 6" rocker height.
    (yes, I tried to search, but failed.)
    t
  • TobyB
    • 5296
    Huh. It's not linear. At all. A shorter, stiffer (by about #50) spring had a #50 softer
    wheel rate. Looks like quick and dirty isn't going to work... but I hate having to get methodical...
    t
    • Jean
      • 18228
      How did you measure?
      • bmwguy325is
        • May 2011
        • 1263
        I paid someone to set up my car. 5 inch spring 750#
        This may help you
        If coil rates baffle you or you want to verify your current set-up this is the calculator for you.
        sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
        The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
        • TobyB
          • 5296
          with a jack under the wheel, and scales under the jack. The springs are by math only-
          but they're Eibach, and 'should' obey reason...
          t
