GC coils
  • limp mode
    • Jun 2012
    • 117
    GC coils
    can someone shed some light on the differences between both?
    AND
    how low do this coils go.. should i get the housings shortened? Im trying to go extreemly low and have the option to raise it up and hit the track. Also whats a good spring rate i should run? thanks in advance
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    The only think I think is different is the front camber plates
    88 325is Five Speed
    Lachssilber
    • lambo
      Captain Scene Points
      • 10953
      Call GC. They will take care of you. If you're looking to go low, get your struts shortened. Mine are shortened and I have them spun all the way up and it is still rather low. My spring rates are 450f 700r and they seem good.
      But, seriously...call GC and ask them.
      Last edited by lambo; 08-20-2012, 09:15 PM. Reason: Fixed the rear spring rates...
      • limp mode
        • Jun 2012
        • 117
        Originally posted by lambo
        Call GC. They will take care of you. If you're looking to go low, get your struts shortened. Mine are shortened and I have them spun all the way up and it is still rather low. My spring rates are 450f 600r and they seem good.
        i just talked to them and they said to shorten the struts.. was not looking forward to spending this much cash for my side car lol. are those spring rates stiff enough??
        • jizo
          • 1191
          +1
          the camber plates are different. If you are going to track get the race plates. Also, I had my set shortened by 2" by them. You would have to send them your stock housings for them to do this for you,if not, its $600 more than the price listed. Other than that, I am extremely happy.
          Overall, The touring plates are sooooo much easier to adjust and are awesome for street!!!!
          • lambo
            • 10953
            I don't bottom out at all. The PO got them for track and auto-x applications mainly.
            Edit: Also, I edited my previous post. Should be 700r, not 600...
            • Robert
              • Dec 2010
              • 3770
              500f/750r
              • acolella76
                • 2950
                I wouldn't choose a rear spring rate more than 150% of what the front is. Sometimes if the difference is greater than 150%, the car will see-saw through corners. Keep that in mind.
                -Alex
                • Hellabad
                  • 807
                  If you request, GC can make a kit for you to shorten your own struts.
                  The price is the same if you shorten your own struts
                  Instructions are made based on your requests, and sent with the kit. If you have a good friend with a MIG welder, then it might only cost you some beer.
                  Jay from GC
                  Here is my photo gallery answering common questions about Ground Control Suspension, and e30 suspension problems in general.
                  Ground Control Gallery
                  The Ground Control facebook page: Dragged, kicking and screaming into social media to see what happens next.
                  • limp mode
                    • Jun 2012
                    • 117
                    thanks i think ill have gc shorten them beacause i want it to be repowder coated and stuff. just do it right the first time.and for spring rates im guessing 700r and 600f? or 500f? it would be nice to have a confortable ride but still be like glue on the road
                    • TeaJhey
                      • Feb 2012
                      • 12
                      how much does it run to have the struts shortened?
                      • limp mode
                        • Jun 2012
                        • 117
                        200$ -_-
                        • yeaseth
                          • Jul 2011
                          • 302
                          I just went through a similar process with ground control. There an awesome company. If you just call them they'll set you up for what you needs are and how much you want to spend. The prices on there are just a guideline. Make sure you get the top adjustable shocks in the back... I run 450f/750r with 22,19 sways, it works great. I talked to Jay
                          benvideoproductions.com
                          http://www.youtube.com/watch?v=617yNrOrRfo&
                          • F34R
                            sLaughter
                            • 12376
                            Another 1+ for calling them, they will help you with spring rates and get you setup for your needs.
                            Instagram: @BWeissLeather
                            Current cars:
                            ~ '87 325 M30B35 swap
                            ~ '87 535
                            ~ 01 540 Msport 6spd
                            ~ '06 X5 4.8is
