Help: Am I totally F'ed? CABs
  • Mastrcruse
    • Sep 2005
    • 5340
    So thought I'd attempt to change the CAB's. I started and this was the result. Its heading over to the BMW mechanic to have them finished up but will he be able to get this out? The head sheared off the bolt.
  • mr.vang
    • 4371
    drill out that bolt and tap in a new thread or make a cut in it and try to screw it out with a flathead. good luck
      That can probably be removed with a left hand twist drill. The trick is to start the drill centered on the stub of the bolt.
      • E30_fiend
        • Apr 2006
        • 7348
        What Jim said.
        To make it a little easier, get a really small drill bit and start that in the very center. It will be much easier to get the left handed bit started. If you don't have a smaller drill bit, a center punch will do the trick as well.
        Taylor
        • Robert
          • Dec 2010
          • 3770
          Just snapped one of my front subframe bolts.. lets hope i can get it out..
          • E30_fiend
            • Apr 2006
            • 7348
            Those are easier because they are just studs that seat in tge body. As long as part of the subframe aluminum sleeve didn't break off too, its as easy as getting a hammer and punch and driving the stud up toward the interior of the car.
            • yeaseth
              • Jul 2011
              • 302
              dang that wouldn't be fun, you could notch it out with a dremil and unscrew it with a screwdriver?
              benvideoproductions.com
              http://www.youtube.com/watch?v=617yNrOrRfo&
                The same technique will work. I've done that before. Once you get the stub out, run a thread chasing tap in to all of the bolt positions and use grease on the bolts to keep moisture out of the threads.
                • jeffnhiscars
                  • Jun 2011
                  • 6011
                  Originally posted by jlevie
                  ...run a thread chasing tap in to all of the bolt positions and use grease on the bolts to keep moisture out of the threads.
                  I remember Jim saying this just when I was getting too much resistance bolting in a lollipop so I stopped and went to get a tap. Based on the crap that came out Im sure that saved me from shearing the bolt.
                  An M10 1.5 tap also does the head bolt holes so should be on everyone's list of essential tools and is a bargain at $4.50 from Grainger.
                  Alice the Time Capsule
                  • Click
                    • 637
                    These spiral flute extractors have saved my ass many times. Just drill a shallow hole in the offending stud and put the extractor in. The extractor will bit into the walls of the hole and pull out the stud.
                    ส็็็็็็็็็็็็็็็็็็็็็็็็็
                    I need you to exfoliate my ballsack
                    Build Thread?
                    • Click
                      • 637
                      http://www.ebay.com/itm/Internationa...#ht_500wt_1414
                      Build Thread?
                      • E30_Pare
                        • 7801
                        Kewl. Looks like fan. I hate broken boltS
                        DREWLIENTE
                        1$ PShops PM me
                        • iansane
                          • 1342
                          Left handed drill bit > extractor
                          84 325e - 91 325i - 92 318 touring - 91 Trans Am - 01 S4 avant - 03 S-type R - 96 F350 - 15 SS - 84 Biturbo - 91 Defender
