I'm starting to see shocks in my dreams from researching this crap so much. I want a suspension that rides as close to stock as possible with about a 1.5" drop. I have the springs I just need the shocks! I would like bilsteins for the reliability but I'm not sure I would like the ride. The car is my daily ride and will likely not see very many tracks/autox events.
What are my shock/damper options for lowered car with comfort in mind
Take an inch out of the front internal bump stops. Ride quality will be great with the Bilsteins.2006 GMC Sierra 2500HD 4WD LBZ/Allison
2002 BMW M3 Alpinweiß/Black
1999 323i GTS2 Alpinweiß
1995 M3 Dakargelb/Black - S50B32/S6S420G/3.91
1990 325is Brilliantrot/Tan
1989 M3 Alpinweiß/Black
sigpic -
Bilsteins. They are valved for 350lb/in rate springs (as I was told by bilstein)
They will be great. with your springs.
You want to revalve once you start getting up toward higher spring rates, or when you want the best handling possible. Revalve cost about $75 per shock I believe. For a stock DD, I would not fret.Comment
sigpicComment
- Josh
1990 325is
Need a shift boot?
Looking to buy shift boot frames, PM if you have one to sell
Here's what happens when you let the internet pick your license plateComment
That said, to get as close to the stock feel I agree with Jim on the settings. I would probably consider dialing mine slightly softer if I were DD'ing the car.Comment
The alteration for lowering was a longer droop spacer. They don't extend as much so the springs don't fall out in the back and they don't run into TUV issues with the spring coming unseated up front. They didn't make any changes that actually make a difference to the way the car drives.2006 GMC Sierra 2500HD 4WD LBZ/Allison
sigpicComment
