How long to do e36 rack swap?
  • havand
    • Sep 2004
    • 171
    Like the title says.
  • Herr Faust Schinken
    • Feb 2012
    • 3580
    like in hours
    88 325is Five Speed
    Lachssilber
    • frankie591
      • Feb 2012
      • 545
      4 hrs maybe
      • ZM Blue Devil
        • Dec 2006
        • 13836
        going into airbag or non airbag car?
        Levent
        %20levent@gutenparts.com
        Ladies:
        • havand
          • Sep 2004
          • 171
          Yes, in hours.
          Non airbag car.
          Supposed to leave for the track on Wednesday afternoon. Wondering if I can get this done when I get home from work tomorrow. In diagnosing a tire balance issue, I found some play in my steering rack. With the car in the air, I can grab a front wheel and shift is some at the 9 and 3 positions. Not a bad tirerod as the other wheels moves the same. Seems like play between the input shaft and the actual rack. Thinking it is worn? I have an e36 rack with tierod ends in the garage.
          Thanks for the replys, guys.
          • AndrewBird
            The Mad Scientist
            • 11898
            Check the steering u-joint for play. The rubber donut can wear out and create a lot of slop.
            • havand
              • Sep 2004
              • 171
              I had someone move the wheel while the car was in the air. It seemed like the entire u-joint moved together. The shaft going into the steering rack rotated a bit before the wheels moved.
              • Todd Black 88
                • Oct 2007
                • 3449
                Took me about 3 hrs the first time, about 1.5hrs the second.
                Originally posted by codyep3
                I hope to Christ you have looks going for you, because you sure as fuck don't have any intelligence.
                2001 silver/Blk 325 cabby. SOLD
                2002 325xit Sil/blk. SOLD
                2010 F650gs twin
                  • Feb 2012
                  • 3580
                  Yeah 3-4 hours is about right I think it took me and my friend about 4 but we also replaced the res and all the lines too
                  88 325is Five Speed
                  Lachssilber
                  • jeffnhiscars
                    • Jun 2011
                    • 6010
                    You may want to grab the knuckle adaptor kit from e30tech, especially if down time is short.
                    Alice the Time Capsule
                    • havand
                      • Sep 2004
                      • 171
                      Ok. Thanks for the time estimates. I am one of those that the 1st time doing something seems to take forever... then the next time it takes about 1/4 as long. Probably tough to pull off in <3 hrs of sunlight outside. Sounds like a project for another day.
                      • frankie591
                        • Feb 2012
                        • 545
                        if you do the swap, modify the e30 linkage by drilling the rivets and removing the rubber flex disc. Then you can just bolt the 2 halves of the linkage together to shorten it to the length needed for the e36 rack. The bolt/spacer kits for sale are a rip off.
                        • future rs
                          • Aug 2012
                          • 514
                          Whats the major difference in the swap from non airbag to airbag?
                          I believe my car is an airbag version. (steering wheel was swapped for non airbag though)
                          Will certain racks not fit? Is there further modification?
                          • FredK
                            • 14761
                            An airbag car doesn't need the knuckle to be modified. It, in my experience, has required clearancing the hole in the firewall for the steering column around 1/2".
                            • future rs
                              • Aug 2012
                              • 514
                              So it puts the steering column at a different angle and needs more clearance? Is this a dremel type procedure?
                              Sorry for all of the questions. I like to have all my t's crossed before starting a project.
                              Would a Z3 rack fit in an airbag car? thanks :)
