sway barrrr
  • Not a 4 door
    • Sep 2012
    • 8
    sway barrrr
    Kinda new to the e30 scene... bare with me :D
    Is there a sway bar that will clear an m50 swapped e30?
    If so, where would i be able to find one????
    thanks!
    Bones would know.
  • mr ilia
    • May 2011
    • 582
    You mean strut bar? The one under the hood?
    • Boise
      • 212
      Since the front sway bar mounts under/behind the front subframe, and your e34 m50 oil sump in front, I don't see any clearance issues with most or all aftermarket sway bars.
        • 37833
        Any swaybar set should clear with no issues.
        Grover Beach, California
        BimmerHeads.com
        • Not a 4 door
          • Sep 2012
          • 8
          Ahhh thanks guys but yes... I meant strut bar haha.
          Bones would know.
          • SkiFree
            • Jun 2011
            • 2766
            The Sparco or Ireland Eng. bar should fit. Just be sure to check the distance between your shock towers.
            ADAMS Autosport
            • Not a 4 door
              • Sep 2012
              • 8
              OK thanks! But.... when I check the distance, from what points on the towers am I measuring from?
              Bones would know.
              • Not a 4 door
                • Sep 2012
                • 8
                And are we talking about this one? It looks very similar to the picture posted above.
                Bones would know.
                • korky
                  • Sep 2012
                  • 100
                  the distance between the strut towers should be 1002.2mm +/-2mm (39.5"), measured from center to center at the strut bearing opening in the inner fenders.
                  1984 bronzit 323i // Euro & M-tech 1.
