E36 318i rear springs
  • e30patalohas
    • Mar 2012
    • 44
    Hello,
    I am looking to lower my '84 325e moderately. I have a pair of e36 318i rear springs. I know that they will fit but does anyone know how these will affect the rear ride height and or spring rate?
    I am mostly curious because I already have the springs in hand.
    Thanks!
  • Vivek
    attention whore/retard/bitch
    • 6167
    It'll most likely go up. What's the free length of those springs? If it's over 9-ish inches don't even bother. They're probably a stiffer rate than the e30 springs.
    1992 Mauritiusblau Vert
    2011 Alpinweiss 335is coupe
    2002 540i/6 Black/Black
    2003 GSX-R 750 (RIP)
      • 37834
      Agreed, I wouldn't be surprised if they RAISED the car.
      If you want cheap go with E30 M3 springs or the ST springs.
      Grover Beach, California
      BimmerHeads.com
      • e30patalohas
        • Mar 2012
        • 44
        Ok I agree the overall length is 9 1/2"... So no go on the rears I bet. I did just read the ST thread and ordered a set so should be good to go. BTW is 2" too low for 16" x 8" bbs style 5s with adapters, final offset +5 mm front, using 205/45-16s? This is for an early '84 325e, again...
        • Vivek
          • 6167
          I would say it'll be pretty damn close, but there's a wheel and tire fitment thread for that. I don't know how much I'm dropped over stock, but 205/50/16 with an offset like that rubbed constantly for me (I tried it, and constantly means 100% of the time, front and rear). I think that you should consider going with slightly thinner adapters unless you'll be running camber plates. Even if it doesn't rub at that height, that's a pretty aggressive offset and you could end up pulling out a fender lip or worse.
          • e30patalohas
            • Mar 2012
            • 44
            Thanks for the input, I did a test mount with one tire 205/45 and it has a nice roll to the tread so hoping that there will be more clearance. Maybe I'll switch to the wheel fitment thread.
