HDs how low...
  • e30patalohas
    • Mar 2012
    • 44
    HDs how low...
    So I have a set of Bilstein HDs on my 84 325e that's 4 wheeling right now. How low can I go with the HDs before I run the potential of turning them into crap?
    1", 1.5" or 2"???
  • dantheman
    • Sep 2011
    • 383
    I don't think it's how low you go as much as the spring rate of the springs you end up using. I have an Eibach Prokit from an M3 with HDs that gave me about a ~1.75" drop and they've held up great. However, the spring rate on the prokit is very low and the suspension is soft.
    If you went with something stiffer like for example, H&R race, the HDs wouldn't last you very long at all.
    Here's a list of spring rates to give you an idea..
    Spring---------------------Front(lb/in.)-------------Rear(lb/in.)
    Stock 325i*-----------------------106------------------------245
    Stock 325is*----------------------118------------------------265
    Stock 325ix*----------------------106------------------------308
    Stock M3*-------------------------114------------------------314
    Stock M3--------------------------140------------------------250
    Dinan Sport-----------------------172------------------------300
    H&R OE Sport---------------------180------------------------380
    H&R Sport-------------------------180------------------------380
    H&R Sport (29664)---------------200------------------------285
    H&R Race-------------------------315------------------------ 570
    H&R Coilovers***----------------340------------------------380
    Eibach Pro-Kit--------------------102-------------------------277
    Eibach Race----------------------160-------------------------445
    IE SIII----------------------------315-------------------------570
    Koni Coilovers-------------------342-------------------------407
    Cosmo Coilovers----------------450-------------------------560
    Tokico----------------------------165-------------------------265
    TMS J-Stock**-------------------680------------------------1026
    Alpina(est.)---------------------~200-----------------------~350
    FK 60/60 cup kit-----------------379--------------------------379
    Vogtland Standard***--------115/197-----------------------360
    Vogtland CS***---------------137/200-----------------------400
    Vogtland--------------------------225--------------------------360
    Intrax-----------------------------126--------------------------250
    • dantheman
      • Sep 2011
      • 383
      Btw: I am going to be ordering a set of Cosmo or GC coils with high spring rates. I'll run them with the HDs and let you know how quickly they blow up lol.
      • e30patalohas
        • Mar 2012
        • 44
        Ahh, ok so spring RATE is much more important than actual drop, unless u get nuts lowz! Thanks for the information, makes things more interesting for me with more options now.
        Keep us posted on how long it takes your HDs to impode, Dan.
        Thanks!
          • 37833
          I'd run them on anything up to H&R Sport. A buddy had them in his car with those springs and they were excellent.
          Grover Beach, California
          BimmerHeads.com
          • dantheman
            • Sep 2011
            • 383
            Will do, sir!
            This.
              • 34844
              the solution to this problem is to get them revalved. :)
              • Mr. Tasty
                • Jul 2011
                • 3421
                are HD's the same as Sports when it comes to revalving? Are Hd's revalved to 450# springs the same as Sports in the same condition?
                2014 Alpine White 335i MSport
                (Daily Driver)
                Full Mperformance Aero
                KW V2 Coilovers
                VRSF Catless Downpipes
                  • 34844
                  Yes
                  • e30patalohas
                    • Mar 2012
                    • 44
                    Anyone know how much it would be or what the process of regaining HDs to Sport involves?
