H&R/Bilsteins ; =( Daily Driver
  • zandi
    • Apr 2004
    • 602
    So I've had the H&R/Bilstein combo in my car for a few months now and I've come to realize that although I do love the look of a lowered car, it's really not so comfortable, well not so much that it's not comfortable, it's really annoying hearing the sound of going over things whenever I go over almost anything, even small potholes and bumps, which we have a lot of in L.A.
    Does anyone recommend a good solution? Should I just go back to stock shocks and stock springs? Or is there maybe some better spring/shock combo that I can have to have a sporty look without the annoying stiffness.
  • Dave
    E30 RAT
    • 11675
    H&R sports or race?
    If its Sports and that's too harsh, I'd recommend somehting for you like an Electra 225 or A Sedan DeVille.
    If its Race, then try the Sports.
    Current Cars
    2014 M235i
    2009 R56 Cooper S
    1998 M3
    1997 M3
    • zandi
      • Apr 2004
      • 602
      Bilstein sports,
      I think I'm confused then that my car is a sports car, or maybe its to do with something else? Maybe balance, or my tires (Azeni Sports) ?
      • DEV0 E30
        • Oct 2004
        • 8904
        I'll trade you never mounted Eibach Pro-Kit for your H&R, will be a softer ride with around the same drop if you are serious.
        Spring -> Lb Front -> Lb Rear
        H&R Sport -> 185 -> 380
        Eibach Pro-kit -> 102 -> 277
        You should get your tires balanced but most suspension setups will stiffen the ride and the ride quality will diminish, it's a fact.
        • zandi
          • Apr 2004
          • 602
          Deal. Let's trade. PM me
          • StereoInstaller1
            GAS
            • 22679
            Zandi, what are you running for tire pressure?
            Luke
            Closing SOON!
            Thanks for 10 years of fun!
            • zandi
              • Apr 2004
              • 602
              34 psi all around.
                • 37833
                John, I bet you'd be a lot happier with the Eibachs for what you want
                Grover Beach, California
                BimmerHeads.com
                • Digitalwave
                  is a poseur
                  • 6299
                  I don't really know what your problem is, but you shouldn't "hear" anything more no matter what springs you have. I'd say you have some worn out suspension parts like ball joints and bushings causing rattles. Softer springs won't solve that.
                  RISING EDGE
                  • silversleeper
                    • Mar 2005
                    • 2032
                    We haven't even figured out if he has H&R race or sports?
                    Also, with Bilstein Sports, you can get them rebuilt for about $75 each and have them customized as far as the valving goes.
                    Claus Luthe is my hero.
                    • Old'n'Slow
                      • 436
                      I have Eibachs as well and like the ride, but I think it's the shock damping that's the issue in your situation, not the spring rates.
                      Bilsteins override the spring-that is, they take the motion out too quickly, and this gives a harsh, jarring ride (to me).
                      Koni SAs on full soft (not really soft, but it's relative) give a sweet, controlled daily-driver-approved ride for us mere mortals who prefer not to drive back and forth to work in a race car.
                      I'd change the dampers (shocks) first. BTW, the Konis ride nicer than Boge Turbos...
                      • 1991 318is
                        • Dec 2005
                        • 786
                        Stiff springs.
                        Lowering springs are stiffer to compensate for the increased roll.
                        http://e30m3performance.com/myths/We..._transfer2.htm
                        You can try the softer springs/shocks for the potholes and "ride". If it rolls too much, use a stiffer bar to compensate. BMW aftermarket suppliers stress the stiff spring/shock approach as opposed to the soft spring/sway bar approach for lowering. I feel the first makes a better track car and the second a much better car for the street.
                        • Axxe
                          • Aug 2004
                          • 3355
                          Except that the car bottoms out on everything. Eibach Pro Kits are stock stiffness and a lot lower. Bad.
                          Keep it slideways!!
                          • Rob
                            • 8166
                            azenis are a lot stiffer than a lot of other tires
                            BEERTECH
