camber correction help plz
  • dustyperez
    • Feb 2012
    • 390
    So i have a 89 325is. i have just purchased the st springs that were a deal on ebay. i got the 1 inch drop m3 springs. what kind of correction kits will i need to get it aligned correctly. im not doing anything drastic just lookin to stiffin it up and give it a better stance.
    • 37829
    No camber correction is really necessary for a 1" drop. Unless you plan to drop hundreds more run it as-is.
    If you do want camber correction I recommend Ground Control Touring camber plates up front and Ireland Engineering weld-in camber correction in the rear. Keep in mind that the rear involves dropping the subframe which means you'd want to do the subframe and trailing arm bushings at the same time.
    Classic BMW Specialists
    Grover Beach, CA
    www.BimmerHeads.com
    • dustyperez
      • Feb 2012
      • 390
      Well as I stated they are 1 inch drop "M3" springs going on an "is" so i assume they will drop it 1.5+/-
      • FunfGan
        • Jan 2011
        • 4958
        That's his point. You'll gain very little(if any at all in the front), and with that small of a drop in the back, you won't be very far into the camber curve.
        Go here be happy!
        Ratchet Garage e30 V8 build.
        • dustyperez
          • Feb 2012
          • 390
          so how much drop is needed before you DO need camber kits??
          • SkiFree
            • Jun 2011
            • 2766
            Depends if the trailing arms or strut tubes are bent, how much tire wear you find acceptable, what kind of use you're using the car for. It's a moving target.
            Personally, doing anything like IE stg 3/H&R Race springs or more would be a good starting point for Matt's prescription of Ground Control Tourings in front and IE weld-ons in the rear. But again, its a moving target.
            ADAMS Autosport
            • dustyperez
              • Feb 2012
              • 390
              perfect!! thx guys
