Comfort Before Style
  • Deathtoll
    • Aug 2012
    • 1285
    Okay, So unlike most of you i'm not as concerned with getting closer to the ground as I am with comfort. I'm looking to get a smooth and comfortable ride as possible without doing anything too crazy. I keep hearing Koni make very comfortable shocks but hey..
    Anyways I want to know a very comfortable suspension setup that I could drive around in. I'm not concerned with extreme cornering and I will probably never take it to the track. I'm not looking to make it look like it's lifted but I do want something that gives me just a tiny bit of ground clearance.
    I want the springs to be soft and high quality but nothing that makes me ground out becuase they are too soft.
    Can someone recommend any suspension setups that will appease me?
    -Art
    Stock IS (or H&R Sport) springs and Koni SA shocks initially set 1/2 turn from full soft.
    • Deathtoll
      • Aug 2012
      • 1285
      Good information
      Here's a question
      are the springs on a 325is the same on an early model and late model? I'm asking because i'm finding alot differences in other areas such as electrical.
      -Art
        You can check part numbers on realoem.com, but I think all 325is sport suspension springs are the same.
        • rasputin
          • Sep 2012
          • 149
          vogtlands and billstein sports, comfy, low, and affordable
          • Deathtoll
            • Aug 2012
            • 1285
            Do the oe springs lose their resiliancy over time?
            -Art
            • pandaboo911
              • 2070
              Install some GC coilovers and some front seats out of a crown vic! Or sit on a pillow.
              To answer your question, keep the stock springs, any aftermarket stuff will be stiffer.
              • Deathtoll
                • Aug 2012
                • 1285
                My spring are supposedly hr race. Came with the car
                -Art
                • grippymonkey
                  • Jun 2011
                  • 759
                  ^ and how are they to you? your definition of soft or comfy can be different from others.
                  GRIPPY'S*GARAGE
                  • Deathtoll
                    • Aug 2012
                    • 1285
                    They are harsher than I would like though other E30 owners thought it was very soft. My other car is a 2011 c300 and a 2002 e320. If it was just a bit more softer over bumps it would be perfection. I have a feeling one of my rear shocks are bad as it clicks once in a while. When I bought the car I had a blown passenger side strut after I replaced it the car smoothened out somewhat.
                    I'm looking for something that is still slightly firm but not jarring. Right now it's getting there. The new tires I bought helped a good deal I think right now it's just almost there.
                    -Art
                    • mbonanni
                      • Sep 2011
                      • 6236
                      I would say you should replace your shocks to see if it helps with ride quality. If not, sell those springs and get some Suspension Tech springs that are only $70.
                      Someone said they have good drop and are slightly softer than hr races.
                      • Deathtoll
                        • Aug 2012
                        • 1285
                        Thanks man. Got link?
                        -Art
                        • mbonanni
                          • Sep 2011
                          • 6236
                          It was only five threads below yours, but owell
                          • e30trooper
                            • 11576
                            Arthur , I might be down for a trade. Ive got Lowtech springs. They have a bit softer rates than Your races.
                            • Eurospec
                              • 2611
