blow shock?
  • livetheride
    • 444
    blow shock?
    Every time I hit any type of bump, my car's rear end shimmys to the right. It happened so violently on the freeway that my car went completely sideways around a corner after hitting a bump. Does this sound like a blown shock? they are bilstein sports with only about 10k miles on them and I have h&r sport springs. A ripped mount? The mounts don't look great, but dont seem to be wrecked. I haven't had time to get under and examine.
  • ///digitalme
    • Dec 2009
    • 2088
    trailing arm bushings and subframe bushings?
    • livetheride
      • 444
      Both brand new. Installed less than 1 year ago. OEM
      • Vivek
        attention whore/retard/bitch
        • 6167
        Not to be a dick, but couldn't you just check if the shock is blown? Unbolt the 19mm at the bottom and see if it feels normal. If it's too easy to compress and/or doesn't rebound, then it's blown.
        1992 Mauritiusblau Vert
        2011 Alpinweiss 335is coupe
        2002 540i/6 Black/Black
        2003 GSX-R 750 (RIP)
        • livetheride
          • 444
          RSM failed.
          • E30_Pare
            • 7801
            That does not sound normal.
            DREWLIENTE
            1$ PShops PM me
            • unevolved
              • Nov 2011
              • 714
              Your car went completely sideways on the freeway on after hitting a bump? That sounds more like bad driving to me.
              1991 318i SOLD
              2003 325i SOLD
              Racecars and stuff.
              • dustyperez
                • Feb 2012
                • 390
                just yesterday i replaced 2 blown shocks. had absolutely no rebound at all. and my car still handled ok. id say its something else
                • livetheride
                  • 444
                  I was doing 65 around a corner and free hitting the bumps, the car just started sliding sideways. I don't drive poorly. I regained control relatively quickly as well
                  • unevolved
                    • Nov 2011
                    • 714
                    Oh, so it wasn't a full-on 90 degree drift?
                    1991 318i SOLD
                    2003 325i SOLD
                    Racecars and stuff.
                    • livetheride
                      • 444
                      No... It was. I was at full lock to keep it straight
                      • unevolved
                        • Nov 2011
                        • 714
                        I wish I had your interstates.
                        1991 318i SOLD
                        2003 325i SOLD
                        Racecars and stuff.
                        • AndrewBird
                          The Mad Scientist
                          • 11898
                          Blown shocks would in no way cause this. Something is either very wrong with your suspension, or it was driver error.
                          Honestly, the latter is much more likely.
                          • unevolved
                            • Nov 2011
                            • 714
                            For you to lose grip like that, you hit the bumpstops. Wheel rate shot to infinity, the tires were overloaded, and you spun. Blown shocks wouldn't cause this, but good shocks would have helped. Probably from being too low on too-soft springs.
                            1991 318i SOLD
                            2003 325i SOLD
                            Racecars and stuff.
                            • livetheride
                              • 444
                              I am on billy sports and h&r sports. The issue was that my rear passenger shock had blown through the rsm, so when I hit the bumps, that wheel was probably not actually touching the ground.
