Leaky Power steering
  • dnguyen1963
    • Nov 2011
    • 2649
    My PS has decided to leak right after I got 18+ in of snow. The leak is bad, but I have not been under the car to find the leak location. Since it is too cold to work on the car, can I remove the belt to the PS pump without deleting the system temporarily? Some users suggested that it was not a good idea because the pressure inside the rack can be built up over time. Other users said no problem. Let me know what you think. Thanks.
  • FLG
    • Sep 2011
    • 3165
    Remove the belt for now if you need to, you will be fine.
    -Build http://www.r3vlimited.com/board/showthread.php?t=295277
    • Komzorz
      • Jun 2011
      • 332
      Should be fine since the rack isn't lubricated by the fluid. I ran for months with the belt off.
      '87 325is - Schwarz/Schwarz
      • WhyNot
        • May 2012
        • 363
        could be something as simple as the ps hose got pushed by the snow and it might need to be tightened, maybe with new thrust washers?
        if you atr thinking of taking off the belt, cant you just shovel a clean area and jack it up?
        Originally posted by der affe
        What are you going to start a thread about next? "My woman's skinny jeans chaffe my special parts, f*ck skin irritation"
        Originally posted by navid41691
        And no, I use lotion so I don't have to worry about skin irritation.
        '...rolling balls, i'm elated, i'm going dumb now; drinking liquor i'm faded and having fun now; loaded gun and tripping with everyone around; keep me stuck in the sky, i never wanna come down...'...kabosh
        • seatown88
          • 331
          Don't worry about any pressure building up in the system
          • dnguyen1963
            • Nov 2011
            • 2649
            Well, I went under the car tonight and found that the infamous BMW hose clamps were all loose. I put a couple new clamps on and, hopefully, no more leaks.
            Thanks everyone.
            • dnguyen1963
              • Nov 2011
              • 2649
              Solved - Leaking power steering
              The leaks had stopped after replacing/tightening all the clamps.
