Hopefully this will work..........
  • MJTSUB
    • Aug 2004
    • 42
    In my quest to find H&R springs for my 89 iX which are backordered and don't have an accrate ETA, I ordered a set of Autosport springs from Bavarian Autosport. The salesman was able to separate a set of 325is springs for the rear which will lower the rear an 1". And he was also able to seperate a set of e28 528 springs which he said will work on the front and drop the front 1" as well. He said the Autosport springs are made in Germany to their specs. I don't know what the spring rates are but I will be running Koni adjustables all around so I should be able to play with settings to accomadate for the different spring rates. I assume the fronts will be firmer since the 5er is heavier. Anyone have any idea what settings I should run the Konis?
    • 34844
    for the first 500 miles run them on full soft. after that play with the settings until you find what you like.
