Billies - IX or IS is there a difference?
  • IronFreak
    • Dec 2012
    • 3702
    #31
    On to your build thread!.....
    Instagram @rebellionforge
    • IronFreak
      • Dec 2012
      • 3702
      #32
      are these the e28 plates you're running?
      • F34R
        sLaughter
        • 12390
        #33
        Yes sir, you will notice the mod that needs to be done to make them fit. Since the 1,500 kit comes with camber plates am sure you can get the e28 instead of the e30.
        Instagram: @BWeissLeather
        Current cars:
        ~ '87 325 M30B35 swap
        ~ '87 535
        ~ 01 540 Msport 6spd
        ~ '06 X5 4.8is
        • IronFreak
          • Dec 2012
          • 3702
          #34
          yeah, just looking at that part of your build. pretty little notching to create clearance for the bolts.
          • IronFreak
            • Dec 2012
            • 3702
            #35
            Do you have any problems with those camber adjustment brackets that you welded in the back slipping around?
            • F34R
              sLaughter
              • 12390
              #36
              Zero, EASY to adjust!
              Current cars:
              ~ '87 535
              ~ '06 X5 4.8is
              • IronFreak
                • Dec 2012
                • 3702
                #37
                how do you like the z3 rack....I've heard good and bad things, I was thinking in between and doing an e36 rack.
                • nrubenstein
                  • 3148
                  #38
                  I don't know what adjusters F3ar has, but in track cars, people have had trouble with the eccentric based adjusters. I would suggest going to the IE positive lock kit for a track car. It is a bit of a pain to adjust (I've installed/aligned both), but you won't have to worry about it moving around on track.
                  I'm not clear on where your "non-DD, but streetable" use falls on the spectrum, but that is something to be aware of.
                  I will agree, though, that the performance of the GC parts is as good as it gets for your buck. Is there better? Yes. But nthats when you start getting into geometric shock pricing territory.
                  2002 BMW M3 Alpinweiß/Black
                  1999 323i GTS2 Alpinweiß
                  1995 M3 Dakargelb/Black
                  - S50B32/S6S420G/3.91
                  1990 325is Brilliantrot/Tan
                  1989 M3 Alpinweiß/Black
                  • IronFreak
                    • Dec 2012
                    • 3702
                    #39
                    I'll clarify....
                    I won't have a need to depend on it daily, but if I feel like driving it instead of my bada$$ accord I'd be able too. I come from drag racing and motorcycles, I'd really like to build a competitive car I could autocross in to get seat time. I have experience going straight, but when it comes to turns, I like the fundamentals.
                    • IronFreak
                      • Dec 2012
                      • 3702
                      #40
                      Can someone give me the "technical" or machining term for this?? I googled "positive locking plates" "grooved" and "knurled" but I'm not coming up with what I'm looking for. IE kits are sold out. I work for a steel company and am in pretty tight with a few local machine shops I thought about getting some A588 grade bars and having a large chunk up this made so I could build my own.
                      • F34R
                        sLaughter
                        • 12390
                        #41
                        I am using the kit from E30Tech.com, easy to adjust and stays in place.
                        Current cars:
                        ~ '87 535
                        ~ '06 X5 4.8is
                        • IronFreak
                          • Dec 2012
                          • 3702
                          #42
                          Nice, that's a little cheaper the the IE kits too. Good words of wisdom to that kid with the 300hp dream thread. I was in those same shoes 12 years ago haha. Spent all my graduation money at autozone buying off the shelf crap to bolt on.....These sites are so valuable, shut up, search, read, study, research...then ask educated questions, that's when you'll get quality results.
