Billies - IX or IS is there a difference?
  • IronFreak
    • Dec 2012
    • 3702
    "cheaper" hahaha, if they were only $20 I would have already bought them hahaha
    Instagram @rebellionforge
      • 34839
      ah, well, you can find them used. quite often for not a lot of money.
      • Stephen
        Шлем ишака
        • 10774
        Mine were cheap, used, and "dinan valved" which probably means regualr valving, knowing Dinan.
        But i highly recommend them for short setups.
        • IronFreak
          • Dec 2012
          • 3702
          If that's the case, who do I contact to re-valve? Does Koni offer the same thing, re-valving that is? That would be good information to have.
          • F34R
            sLaughter
            • 12376
            Go back to the steering, shocks, sways & steering main page...right above you man ;)
            Instagram: @BWeissLeather
            Current cars:
            ~ '87 325 M30B35 swap
            ~ '87 535
            ~ 01 540 Msport 6spd
            ~ '06 X5 4.8is
            • IronFreak
              • Dec 2012
              • 3702
              ..........doah.
              • dsm2002
                • 193
                From Bilstein:
                BMW 325I HD FRONT
                COLL/EXT: 530.0/618.0
                REB/COM: 2320/800
                BMW 325IX 4WD F
                COLL/EXT: 438.5/511.0
                REB/COM: 1365/465
                BMW 325I SPORT FRONT
                COLL/EXT: 515.0/597.5
                REB/COM: 2330/755
                Confirms what has been said
                • IronFreak
                  • Dec 2012
                  • 3702
                  So I have been adding everything up.....
                  If I use Koni adjustables in all four corners that's about $550-600 depending on where I source the shocks.
                  GC kit is $400 as well.
                  Depending on what I use, caster/camber plates are $350-$400 based on model and brand.
                  I'll add at the high end to cover shipping costs ect...
                  shocks (4) $600
                  GC kit (1) $400
                  caster camber plates (2) $400
                  I'm sitting at roughly $1400 for a good setup. Aren't I in the range of some decent coilovers? I know some people don't like the idea of for blown coils in the back because the shock tower would be supporting all the weight......solution
                  I'm a fabricator and steel is second nature to me. So educate me, I'm not going to go drop 5k on a set of AST's because I'd probably never fully utilize them on this car. But if I could reinforce the shock towers, why not spend around $1000 on some BC coils that I could just slap on, I'd have all the adjustment I would need for what I'd ever use it for........unless I came upon some crazy money in which case I would probably build a whole new car anyways.
                  FE4R.......Speak your mind.
                  • F34R
                    sLaughter
                    • 12376
                    Is that your car above? My thoughts are this:
                    Within budget and will be/do anything you desire. Comes with the rear shock mounts too. Only thing you have to pick is spring rates. Give them a call, ask for Mark or Jay and they will hook you up. Let them know I sent you if you do go for them.
                    Good thing is you can handle shortening the housings yourself. GC is the best for the money, do you really want to cut all that up to just use a coilover rear design? I only see that if you are HARDCORE track with really wide rear wheels.
                    BC is not really that good, and try to get spring rates and dampening info from them lol. Tried for a week straight when I was trying to compare for my Buddies GTI. Ended up waiting out for H&R coils.
                    Current cars:
                    ~ '87 535
                    ~ '06 X5 4.8is
                    • IronFreak
                      • Dec 2012
                      • 3702
                      No it's not my car, it's Zodows hillclimb E30. - http://www.r3vlimited.com/board/showthread.php?t=271303
                      I'm kind of a freak, hence the name. Unlike some people, cutting that up, or any other part of the car for that matter wouldn't phase me.....it's just metal.
                      Thanks for your input though man, I appreciate the non rhetorical educated responses I've gotten from you. Hardcore track you say, wide wheels you say.....maybe I'll do just to make the local Vette and Pony boys piddle a little hahaha.
                        • 34839
                        shocks (4) $600
                        GC kit (1) $400
                        made in china ebay junk are decent coilovers now?
                        vs made in the USA, Germany, and Holland?
                        I get the "budget" aspect of the ebay stuff, but it's still made in china junk for the most part. Mystery spring rates, mystery shock valving, generic parts adapted to fit an E30.. etc. etc.
                        • IronFreak
                          • Dec 2012
                          • 3702
                          Yeah, budget is and isnt a huge factor. Its more of, what am i going to get tge most out of based on cost, and application of the car. Its not going to be a DD, but i want it to be very streetable. Ill continue to do my research and see what i come up with.
                          • F34R
                            sLaughter
                            • 12376
                            The GC setup will do all that and more.
                            @NandoThat is why I ALWAYS rep Grond Control for suspension.
                            USA made and the springs are covered through Eibach(Already had a pair replaced for free). The inserts are top end Koni SA that are made in Holland directly FOR Ground Control.
                            BC is a good budget coilover, but they are never going to live up to Koni inserts and GC's coverage on their OWN parts. Nothing is junk. Whatever path you go is fine because it is your money.
                            For me it is GC or nothing.
                            No problem, that is what I am passionate about.
                            Rears are 17x9 with 235/40, muscle car guys LOVE my rear fitment and tread width. It is just stunning how wide and perfect all that meat is under the arches and not poking out.
                            Current cars:
                            ~ '87 535
                            ~ '06 X5 4.8is
                            • IronFreak
                              • Dec 2012
                              • 3702
                              Yeah that makes sense, I have a question about the kit, it says. "2 Ground Control / Koni single adjustable strut inserts,bolted into existing housings." So I have to send them my housing?? I can, cut, bolt and weld that myself, will that drop the price or am I getting confused?
                              • F34R
                                sLaughter
                                • 12376
                                They offer the kit mod, you don't have to send them anything. Just do it yourself, CALL THEM! tell them what you want the car's use to be. They will take care of you.
                                You want what I built for myself. Take a bit of time and scroll through my build. It is a lot more advanced than a simple bolt on and covers ANY questions you might have. Springs rates, mods improvements etc.
                                PM me for anything.
                                Current cars:
                                ~ '87 535
                                ~ '06 X5 4.8is
