Bilstein HD with lowering springs?
  • MattS67
    • Jan 2013
    • 15
    I just picked up my first E30, a '91 318is. The car recently had all the shocks replaced with Bilstein HD and still has the stock springs with 175k miles on them. It handles like a boat so I want to give it a slight drop and stiffen up the ride a bit. I know Bilstein Sports would be the ideal choice in this situation, but if I drop my car an inch or so, would the HDs work fine or is replacing them with Sports recommended?
    Thanks
    Matt
  • vert_this
    • Feb 2012
    • 395
    sports will ride a lot better IMO.
    • bmwguy325is
      • May 2011
      • 1263
      Air Bags FTW
      sigpic"If one does not fail at times, then one has not challenged himself." -Ferdinand Porsche
      The ugly car: http://www.r3vlimited.com/board/showthread.php?t=209713
      • Jaxx_
        • Dec 2009
        • 1880
        HDs will work fine. In another application that was heavier I lowered the car about 1.5" on HDs and it wasn't a problem. You're not getting close to the bottom of the stroke so I wouldn't worry about it.
        • cholyoke
          • Feb 2006
          • 186
          I have HDs and H&R sports, which I like very much.
          • nrubenstein
            • 3148
            Valving is the same. The basic difference is that HDs extend further.
            You may want to trim an inch off the internal bump stop up front.
            2002 BMW M3 Alpinweiß/Black
            1999 323i GTS2 Alpinweiß
            1995 M3 Dakargelb/Black
            - S50B32/S6S420G/3.91
            1990 325is Brilliantrot/Tan
            1989 M3 Alpinweiß/Black
            • MattS67
              • Jan 2013
              • 15
              Cool deal, sounds like it's not really worth the ~$500 extra. Thanks for the replies guys!
                • 37833
                I've also run HD's with H&R Sport on a M20 powered E30 and it was great!
                Trimming 1/3 off of the front bump stop is a good idea though. I did.
                Grover Beach, California
                BimmerHeads.com
                • MattS67
                  • Jan 2013
                  • 15
                  Well I was told the car had new Bilstein HD shocks, but it has the factory originals. Guess I'm replacing them after all. The joys of buying a used car. :)
                  • Northern
                    I like cupcakes & sh!tboxes
                    • 5284
                    Would go with billy sports over HD's.
                    Originally posted by priapism
                    Originally posted by shameson
