are Koni's rebuildable???
  • greg1333
    • Nov 2004
    • 127
    While moving my project car from one house to another I pulled my never installed Koni adjustable rear shocks out of the box and they were covered with oil. Shaft slides in and out with almost no resistance.
    Does anyone know if they are rebuildable and if so what would it cost???
    • 34844
    Yes.
    Expensive.
    you have the receipt or proof of purchase? they should be covered under warranty.
    • IronFreak
      • Dec 2012
      • 3702
      Look a few threads above yours.....Not cheap but you can have them custom valved to your specs.
      Instagram @rebellionforge
      • greg1333
        • Nov 2004
        • 127
        argh...receipt....never thought it would come to this....
        expensive?...they were about $150 each new....if rebuilding them cost more than half I might just replace the whole lot..
        • IronFreak
          • Dec 2012
          • 3702
          The guy in that thread had Koni NA rebuild and custom valve them for like 265 shipped. $150?? tell me where, the cheapest I can find them is $165 new with free shipping from Konimarket.com. So, $330 for new standard shocks, or $265 for new custom valved....What is the car used for?
          • greg1333
            • Nov 2004
            • 127
            I bought them about 8 years ago from Ground Control as part of a complete kit (struts/shocks/springs/collars/perches). But as far as I remember, that was the breakdown of the cost.
            I installed the fronts, the rears didn't get installed because at the time the crossmember was removed for mods.
            The whole project got put on hold when my life got busy...
            The car is, or will be, used for autocross...
            • DRTSRFR
              • May 2008
              • 1836
              If the dampers were on their side they will have equalized .
              Stand them up vertically and cycle them a few times. If they are good, the damping will come back.
              The fluid could be residual oil in the adjuster/shaft cavity, from the wet assembly process, which has leaked and not the criitical oil in the body of the damper.
              Feel free to call me(530-677-8600) If I can dig up your old invoice, there may be other options.
              Mark
              Suspension tips here...
              http://www.r3vlimited.com/board/album.php?albumid=757
              • IronFreak
                • Dec 2012
                • 3702
                Should have read this a little better, I didn't see you had said rears. Talk with Mark^^^ I have heard nothing but good things about these guys!
                • greg1333
                  • Nov 2004
                  • 127
                  Mark,
                  Thank you for your response..
                  The dampers were infact stored on their side. I will try what you suggested when i get home.
                  • greg1333
                    • Nov 2004
                    • 127
                    Mark, PM sent.....
