Quick question. Bent strut housing. Interchangeable?
  • nickmcc92
    • Dec 2012
    • 442
    Drivers side strut housing is bent from previous owner accident and camber is -3degrees.
    Found a guy selling his off a 1986 325es.
    This will work right? Just want to make sure before I spend money.
  • nickmcc92
    • Dec 2012
    • 442
    Oh yeah my car is 88 325i
    • jeffnhiscars
      • Jun 2011
      • 6011
      Your 88 will have 51mm housings and ABS. Those are the only 2 things that matter and they should be the same on the 86. Easy to check
      Alice the Time Capsule
      • acolella76
        • 2950
        Yup you are good!
        -Alex
        • nickmcc92
          • Dec 2012
          • 442
          Nice thanks guys. Hope this fixes my steering issues
            I think the 86 strut housing will be the 51mm part like you have, but it may not have the wheel speed sensor mount. If it does, it will work.
              • 37832
              All 325eS cars had ABS. Yes it will fit.
              Classic BMW Specialists
              Grover Beach, CA
              www.BimmerHeads.com
                I have an 86 325es that never had ABS. The parts aren't there, which is no surprise since the build sheet says it never had it.
                • nickmcc92
                  • Dec 2012
                  • 442
                  I ended up pulling a housing from the junk yard off a 318.
                  Now I'm having trouble removing ball joint from the spindle.
                  I have a big a** hammer, but I'd rather rent a tool from pepboys.
                  What tool would be best? 2 Jaw puller? Ball joint press?
