Ground Control Clunk? (Video Inside)
  • lambo
    Captain Scene Points
    • 10953
    Alrighty... So, I've had this clunk for a while now. However, it has gotten worse recently.
    It sounds like something is loose and wobbling side to side when driving over repetitive bumps and/or cracks in the road. Even small bumps and cracks cause it.
    My first thought was that it is the bearing in the camber plate but I have no idea. All my nuts and bolts are tight as far as I know. I thought it might be the joint in the endlinks but those are tight with very little play. Also, the driver's front shock is blown but the clunk is coming from both, but mainly the passenger side.
    Any ideas??
    Thanks!
    My setup:
    Ground Control Coilovers
    - 700 or 650f/450r
    - Shortened Housings
    - Race (?) Camber Plates
    - Adjustable M3 Style Endlinks
    - Koni Yellows
    Video:
    1:55 shows the worst of it, I think.
  • lambo
    • 10953
    A little update. Checked the collar nut that holds the insert in the housing and that was tight. Here are some more videos...
    Left Side:
    - Shock is blown, obviously
    - The top mount seems to wobble and make a decent amount of noise. Is that normal?
    Right Side 1:
    - Shock not blown
    - Top mount doesn't wobble as much as the left
    Right Side 2:
    - Sound seems like it is coming from inside the housing...
    • dudecati
      • Jun 2012
      • 104
      What did the folks at Ground Control say when you contacted them?
      • lambo
        • 10953
        Mark told me to check the collar nut, he hasn't mentioned anything else yet.
        • DRTSRFR
          • May 2008
          • 1836
          The upper perches will articulate. They are designed to do so. As the bearings wear, they will begin to move easily.
          It's always tough to analyze a problem via video.
          The Koni may, in fact, be damaged to the point where it is making noise. If the gand nuts are tight and there is internal noise, it's usually the piston in the damper.
          Mark
          Suspension tips here...
          http://www.r3vlimited.com/board/album.php?albumid=757
          • lambo
            • 10953
            That's what I figured, I just wasn't sure if the left one had too much play in it or something. Yeah, I've been stumped by it for too long and this is the best way I could think of to find help, unfortunately...
            Mark
            Since there is lots of internal noise in the right, non-blown damper, is it faulty by some means or is that just how it is,
            Thanks!
            • DRTSRFR
              • May 2008
              • 1836
              To be honest, being you have gone through all of the other methods, I would pull the inserts and, at the very least, re-assemble to eliminate any questions regarding the damper.
              Since you bought these used, there's no telling what could have occured prior to your purchase.
              • lambo
                • 10953
                Sounds like a plan. Only reason I haven't completely disassembled anything is because, with my current living arrangements, I can't have the car nonfunctioning for more than two weeks and I don't really have too much time on my hands. I'll just get the new shocks I need to replace the blown one and go from there.
                Thanks!
                • fporro
                  • 1861
                  My H&R's coilovers used to bind somewhat with K-mac c/c plates, so upgraded to GC c/c units., it then started to make louder clunking noises.
                  I've tried to fix it with brass spacers from local hardware store, pics here ... http://www.bimmerfest.com/forums/album.php?albumid=7557
                  it worked for awhile, but eventually the rattleting cameback, so, called Adam at GC and he sent me a sheet for me to write shock dimentions on.
                  I had the wrong spacers for my setup., a few dollars later all noise went away.
                  Thanks Adam ...
                  wrong spacers are on right bottom, of this pic, also used to stack 2 spring hats (H&R + GC's) to make up for too short of springs, all's fixed now....
                  • Mr. Tasty
                    • Jul 2011
                    • 3421
                    interesting, my car has recently been making the same sounds as lambo's, although not even close to as bad. It almost makes a "bouncy noise" like in his videos. The nut is tight and the struts are far from blown.
                    2014 Alpine White 335i MSport
                    (Daily Driver)
                    Full Mperformance Aero
                    KW V2 Coilovers
                    VRSF Catless Downpipes
                    • lambo
                      • 10953
                      Probably the spacer that people are talking about. I'm gonna dig into it this summer.
                      • Mr. Tasty
                        • Jul 2011
                        • 3421
                        im not running camber plates though. Just factory mounts with 2.5 ID perch. Do I need to be running some sort of metal between the mount and perch?
                        Could I be damaging the strut mounts?
                        (Daily Driver)
                        KW V2 Coilovers
                        • lambo
                          • 10953
                          Well, after looking at it with Apytp, we've pretty much decided that the bearing/mount is shot....
                          • Mr. Tasty
                            • Jul 2011
                            • 3421
                            I think my mounts are prematurely aging also. Looks like I am upgrading to some camber plates.
                            (Daily Driver)
                            KW V2 Coilovers
