Spring pads 9mm or 3mm?
  • noid
    • 1536
    I need to order new spring pads for the front, looking at Realoem/bmwfans there are two options for the upper pad. 9mm and 3mm are the options, which do I need?
    The special note for the for the 9mm is "Only applies to coil spring red ". What does that even mean?
    My e30 came with M-tech suspension from the factory (bilstein HD's). I am using the stock springs and just changing out the shocks with new HD's.
    Your resource to do-it-yourself and interesting bmw and e30 stuff: www.rtsauto.com
    Your resource to tools and tips: www.rtstools.com
    Ether can be used, but your car probably has 3mm pads on it now. The 9mm pad is for the M-tech suspension that has slightly shorter springs.
